We built imx-full-image with opencv toolchain. We are confused between below mentioned .wic image files to flash to IMX board.
Also, should it be flashed with or without extracting?
解決済! 解決策の投稿を見る。
If you are using lastest uuu tool, you can choose flashed it without extracting
