imx8m mini flash img error
1,695 次查看
1269813285
I develop a custom board with imx8m mini ,when we execute the command
"sudo ./uuu_imx_android_flash.sh -f imx8mm -u ddr4 ",
the result is failed .it stop at the result
"3:13 1/ 1 [=================100%=================] SDP: boot -f u-boot-imx8mm-ddr4-evk-uuu.imx "
we doubt whether it is because of the ddr4 .
I noticed that the reference board using 2*16bit DDR4 for memory interface for 32bit data, and we used 1 bit DDR4 for memory for 16 bit data.
I wonder whether it is the cause of our problem.
Maybe we need to modify some code or configuration, Could you please give us some tips?
标记 (1)
1,644 次查看
AldoG
I see that you have 2 threads about the same topic and got a response already from one of my colleagues, please take a look.
https://community.nxp.com/thread/533906
Aldo.
1,644 次查看
1269813285
 we used 16 bit DDR4 for memory for 16 bit data.
1,645 次查看
AldoG
Aldo.
