imx8m mini evk tftp/nfs boot failure
2,325 次查看
Dhevan
     I am trying to boot from tftp/nfs but am getting error.
U-Boot SPL 2020.04-5.4.24-2.1.0+g4979a99482 (Feb 15 2021 - 18:43:53 +0000)
power_bd71837_init
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC2
NOTICE:  BL31: v2.2(release):imx_5.4.24_er3-0-gb0a00f22b
NOTICE:  BL31: Built : 18:52:09, Feb 15 2021
U-Boot 2020.04-5.4.24-2.1.0+g4979a99482 (Feb 15 2021 - 18:43:53 +0000)
CPU:   i.MX8MMQ rev1.0 1800 MHz (running at 1200 MHz)
CPU:   Commercial temperature grade (0C to 95C) at 30C
Reset cause: POR
Model: NXP i.MX8MM EVK board
DRAM:  2 GiB
TCPC:  Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x52]
Power supply on USB2
TCPC:  Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50]
MMC:   FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... OK
[*]-Video Link 0Can't find cec device id=0x3c
fail to probe panel device adv7535@3d
failed to get any video link display timings
probe video device failed, ret -22
        [0] lcdif@32e00000, video
        [1] mipi_dsi@32e10000, video_bridge
        [2] adv7535@3d, panel
In:    serial
Out:   serial
Err:   serial
 BuildInfo:
  - ATF b0a00f2
  - U-Boot 2020.04-5.4.24-2.1.0+g4979a99482
switch to partitions #0, OK
mmc2(part 0) is current device
flash target is MMC:2
Net:   eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot:  0
Booting from net ...
ethernet@30be0000 Waiting for PHY auto negotiation to complete.. done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 192.168.1.19 (1913 ms)
Using ethernet@30be0000 device
TFTP from server 192.168.1.4; our IP address is 192.168.1.19
Filename 'Image'.
Load address: 0x40480000
Loading: #################################################################
         336.9 KiB/s
done
Bytes transferred = 28021248 (1ab9200 hex)
BOOTP broadcast 1
DHCP client bound to address 192.168.1.19 (103 ms)
Filename 'imx8mm-evk.dtb'.
Load address: 0x43000000
Loading: #######
         192.4 KiB/s
done
Bytes transferred = 35630 (8b2e hex)
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Using Device Tree in place at 0000000043000000, end 000000004300bb2d
Starting kernel ...
unable to select a mode
device_remove: Device 'mmc@30b60000.blk' failed to remove, but children are gone
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.4.24 (vasu@vasu) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Mon Feb 22 12:56:16 IST 2021
[    0.000000] Machine model: NXP i.MX8MM EVK board
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 320 MiB at 0x00000000aa000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xa9be3500-0xa9be4fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x00000000bdffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s58904 r8192 d31208 u98304
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 508032
[    0.000000] Policy zone: DMA32
[    0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/nfs ip=dhcp nfsroot=192.168.1.4:/home/vasu/nfs_boot/nfs,v3,tcp
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1667824K/2064384K available (16444K kernel code, 1444K rwdata, 6472K rodata, 2944K init, 1017K bss, 68880K reserved, 327680K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 128 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: no VLPI support, no direct LPI support
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] random: get_random_bytes called from start_kernel+0x2b8/0x44c with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[    0.000003] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[    0.000365] Console: colour dummy device 80x25
[    0.000426] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.000434] pid_max: default: 32768 minimum: 301
[    0.000502] LSM: Security Framework initializing
[    0.000553] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.000565] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.024008] ASID allocator initialised with 32768 entries
[    0.032004] rcu: Hierarchical SRCU implementation.
[    0.040774] EFI services will not be available.
[    0.048034] smp: Bringing up secondary CPUs ...
[    0.080187] Detected VIPT I-cache on CPU1
[    0.080211] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.080244] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.112218] Detected VIPT I-cache on CPU2
[    0.112235] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.112253] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.144267] Detected VIPT I-cache on CPU3
[    0.144282] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.144298] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.144354] smp: Brought up 1 node, 4 CPUs
[    0.144377] SMP: Total of 4 processors activated.
[    0.144382] CPU features: detected: 32-bit EL0 Support
[    0.144387] CPU features: detected: CRC32 instructions
[    0.151046] CPU: All CPU(s) started at EL2
[    0.151064] alternatives: patching kernel code
[    0.152479] devtmpfs: initialized
[    0.157789] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.157807] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.165334] pinctrl core: initialized pinctrl subsystem
[    0.165991] DMI not present or invalid.
[    0.166237] NET: Registered protocol family 16
[    0.174196] DMA: preallocated 256 KiB pool for atomic allocations
[    0.174224] audit: initializing netlink subsys (disabled)
[    0.174451] audit: type=2000 audit(0.172:1): state=initialized audit_enabled=0 res=1
[    0.175215] cpuidle: using governor menu
[    0.175613] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.176381] Serial: AMBA PL011 UART driver
[    0.176443] imx mu driver is registered.
[    0.176466] imx rpmsg driver is registered.
[    0.180953] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.201689] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.201699] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.201705] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.201712] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.203261] cryptd: max_cpu_qlen set to 1000
[    0.208281] ACPI: Interpreter disabled.
[    0.209023] iommu: Default domain type: Translated
[    0.209160] vgaarb: loaded
[    0.209450] SCSI subsystem initialized
[    0.209777] usbcore: registered new interface driver usbfs
[    0.209811] usbcore: registered new interface driver hub
[    0.209858] usbcore: registered new device driver usb
[    0.210893] mc: Linux media interface: v0.10
[    0.210916] videodev: Linux video capture interface: v2.00
[    0.210984] pps_core: LinuxPPS API ver. 1 registered
[    0.210990] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.211004] PTP clock support registered
[    0.211123] EDAC MC: Ver: 3.0.0
[    0.211829] No BMan portals available!
[    0.212051] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[    0.212286] No QMan portals available!
[    0.212657] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[    0.213046] FPGA manager framework
[    0.213121] Advanced Linux Sound Architecture Driver Initialized.
[    0.213487] Bluetooth: Core ver 2.22
[    0.213510] NET: Registered protocol family 31
[    0.213514] Bluetooth: HCI device and connection manager initialized
[    0.213523] Bluetooth: HCI socket layer initialized
[    0.213531] Bluetooth: L2CAP socket layer initialized
[    0.213543] Bluetooth: SCO socket layer initialized
[    0.214171] clocksource: Switched to clocksource arch_sys_counter
[    0.214316] VFS: Disk quotas dquot_6.6.0
[    0.214369] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.214517] pnp: PnP ACPI: disabled
[    0.219940] thermal_sys: Registered thermal governor 'step_wise'
[    0.219943] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220257] NET: Registered protocol family 2
[    0.220573] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.220604] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.220712] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.220941] TCP: Hash tables configured (established 16384 bind 16384)
[    0.221012] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.221056] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.221184] NET: Registered protocol family 1
[    0.221565] RPC: Registered named UNIX socket transport module.
[    0.221570] RPC: Registered udp transport module.
[    0.221574] RPC: Registered tcp transport module.
[    0.221578] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.221927] PCI: CLS 0 bytes, default 64
[    0.222593] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.222913] kvm [1]: IPA Size Limit: 40bits
[    0.223498] kvm [1]: GICv3: no GICV resource entry
[    0.223503] kvm [1]: disabling GICv2 emulation
[    0.223521] kvm [1]: GIC system register CPU interface enabled
[    0.223581] kvm [1]: vgic interrupt IRQ1
[    0.223671] kvm [1]: Hyp mode initialized successfully
[    0.228690] Initialise system trusted keyrings
[    0.228799] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[    0.234534] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.235163] NFS: Registering the id_resolver key type
[    0.235188] Key type id_resolver registered
[    0.235192] Key type id_legacy registered
[    0.235201] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.235219] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.235563] 9p: Installing v9fs 9p2000 file system support
[    0.248995] Key type asymmetric registered
[    0.249002] Asymmetric key parser 'x509' registered
[    0.249040] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.249046] io scheduler mq-deadline registered
[    0.249051] io scheduler kyber registered
[    0.253298] EINJ: ACPI disabled.
[    0.260540] imx-sdma 302c0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2
[    0.260552] imx-sdma 302c0000.dma-controller: Falling back to sysfs fallback for: imx/sdma/sdma-imx7d.bin
[    0.268154] mxs-dma 33000000.dma-controller: initialized
[    0.268967] Bus freq driver module loaded
[    0.273882] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.275842] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 27, base_baud = 1500000) is a IMX
[    1.226765] printk: console [ttymxc1] enabled
[    1.235279] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.241913] [drm] No driver support for vblank timestamp query.
[    1.247912] imx-drm soc@0:bus@32c00000:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[    1.257331] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[    1.264351] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[    1.272628] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -19
[    1.280301] imx-drm soc@0:bus@32c00000:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[    1.289993] [drm] Initialized imx-drm 1.0.0 20120507 for soc@0:bus@32c00000:display-subsystem on minor 0
[    1.308385] loop: module loaded
[    1.313487] imx ahci driver is registered.
[    1.320635] libphy: Fixed MDIO Bus: probed
[    1.325492] tun: Universal TUN/TAP device driver, 1.6
[    1.331293] thunder_xcv, ver 1.0
[    1.334563] thunder_bgx, ver 1.0
[    1.337822] nicpf, ver 1.0
[    1.341544] Freescale FM module, FMD API version 21.1.0
[    1.346995] Freescale FM Ports module
[    1.350664] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[    1.356369] fsl_dpa: FSL DPAA Ethernet driver
[    1.360821] fsl_advanced: FSL DPAA Advanced drivers:
[    1.365793] fsl_proxy: FSL DPAA Proxy initialization driver
[    1.371463] fsl_oh: FSL FMan Offline Parsing port driver
[    1.377541] hclge is initializing
[    1.380867] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    1.388094] hns3: Copyright (c) 2017 Huawei Corporation.
[    1.393448] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    1.400502] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.406289] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    1.412125] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.418086] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.6.0-k
[    1.425053] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.430658] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    1.438497] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.444578] sky2: driver version 1.30
[    1.449083] VFIO - User Level meta-driver version: 0.3
[    1.455913] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.462462] ehci-pci: EHCI PCI platform driver
[    1.466949] ehci-platform: EHCI generic platform driver
[    1.472339] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.478541] ohci-pci: OHCI PCI platform driver
[    1.483019] ohci-platform: OHCI generic platform driver
[    1.488777] usbcore: registered new interface driver usb-storage
[    1.494848] usbcore: registered new interface driver usbserial_generic
[    1.501398] usbserial: USB Serial support registered for generic
[    1.507429] usbcore: registered new interface driver ftdi_sio
[    1.513196] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.520530] usbcore: registered new interface driver usb_serial_simple
[    1.527076] usbserial: USB Serial support registered for carelink
[    1.533189] usbserial: USB Serial support registered for zio
[    1.538866] usbserial: USB Serial support registered for funsoft
[    1.544896] usbserial: USB Serial support registered for flashloader
[    1.551271] usbserial: USB Serial support registered for google
[    1.557211] usbserial: USB Serial support registered for libtransistor
[    1.563760] usbserial: USB Serial support registered for vivopay
[    1.569790] usbserial: USB Serial support registered for moto_modem
[    1.576079] usbserial: USB Serial support registered for motorola_tetra
[    1.582712] usbserial: USB Serial support registered for novatel_gps
[    1.589088] usbserial: USB Serial support registered for hp4x
[    1.594856] usbserial: USB Serial support registered for suunto
[    1.600791] usbserial: USB Serial support registered for siemens_mpi
[    1.608515] imx_usb 32e40000.usb: No over current polarity defined
[    1.614865] imx_usb 32e50000.usb: No over current polarity defined
[    1.622281] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/soc@0:bus@30000000/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[    1.637311] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[    1.643584] i2c /dev entries driver
[    1.651579] imx2-wdt 30280000.watchdog: timeout 60 sec (nowayout=0)
[    1.658127] Bluetooth: HCI UART driver ver 2.3
[    1.662586] Bluetooth: HCI UART protocol H4 registered
[    1.667731] Bluetooth: HCI UART protocol BCSP registered
[    1.673066] Bluetooth: HCI UART protocol LL registered
[    1.678211] Bluetooth: HCI UART protocol ATH3K registered
[    1.683636] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.689987] Bluetooth: HCI UART protocol Broadcom registered
[    1.695672] Bluetooth: HCI UART protocol QCA registered
[    1.702765] sdhci: Secure Digital Host Controller Interface driver
[    1.708957] sdhci: Copyright(c) Pierre Ossman
[    1.713479] Synopsys Designware Multimedia Card Interface Driver
[    1.720017] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.726428] mmc1: CQHCI version 5.10
[    1.730509] mmc2: CQHCI version 5.10
[    1.766526] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    1.776243] ledtrig-cpu: registered to indicate activity on CPUs
[    1.783447] caam 30900000.crypto: device ID = 0x0a16040100000000 (Era 9)
[    1.790214] caam 30900000.crypto: job rings = 2, qi = 0
[    1.839477] caam algorithms registered in /proc/crypto
[    1.852996] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[    1.863123] caam_jr 30901000.jr: registering rng-caam
[    1.870938] caam-snvs 30370000.caam-snvs: can't get snvs clock
[    1.876898] caam-snvs 30370000.caam-snvs: violation handlers armed - non-secure state
[    1.885356] usbcore: registered new interface driver usbhid
[    1.890949] usbhid: USB HID core driver
[    1.896547] No fsl,qman node
[    1.899462] Freescale USDPAA process driver
[    1.903657] fsl-usdpaa: no region found
[    1.907543] Freescale USDPAA process IRQ driver
[    1.908471] mmc2: Command Queue Engine enabled
[    1.915551] optee: probing for conduit method from DT.
[    1.916579] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    1.921725] optee: revision 3.7 (7a49776d)
[    1.923049] optee: dynamic shared memory is enabled
[    1.928660] mmcblk2: mmc2:0001 DG4016 14.7 GiB
[    1.932353] optee: initialized driver
[    1.937192] mmcblk2boot0: mmc2:0001 DG4016 partition 1 4.00 MiB
[    1.944761] wm8524-codec audio-codec: Failed to get mute line: -517
[    1.945431] mmcblk2boot1: mmc2:0001 DG4016 partition 2 4.00 MiB
[    1.954369] fsl-sai 30030000.sai: failed to get mclk0 clock: -2
[    1.957913] mmcblk2rpmb: mmc2:0001 DG4016 partition 3 4.00 MiB, chardev (237:0)
[    1.968687] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    1.976690]  mmcblk2: p1 p2
[    1.988498] NET: Registered protocol family 26
[    1.993530] NET: Registered protocol family 10
[    1.998614] Segment Routing with IPv6
[    2.002336] NET: Registered protocol family 17
[    2.007163] Bluetooth: RFCOMM TTY layer initialized
[    2.012059] Bluetooth: RFCOMM socket layer initialized
[    2.017229] Bluetooth: RFCOMM ver 1.11
[    2.020989] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    2.026306] Bluetooth: BNEP filters: protocol multicast
[    2.031540] Bluetooth: BNEP socket layer initialized
[    2.036510] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.042439] Bluetooth: HIDP socket layer initialized
[    2.047438] 8021q: 802.1Q VLAN Support v1.8
[    2.051645] lib80211: common routines for IEEE802.11 drivers
[    2.057412] 9pnet: Installing 9P2000 support
[    2.061713] tsn generic netlink module v1 init...
[    2.066484] Key type dns_resolver registered
[    2.071732] registered taskstats version 1
[    2.075841] Loading compiled-in X.509 certificates
[    2.099146] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[    2.107955] usb_phy_generic usbphynop2: usbphynop2 supply vcc not found, using dummy regulator
[    2.116929] gpio-144 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
[    2.126917] adv7511 1-003d: 1-003d supply avdd not found, using dummy regulator
[    2.134278] adv7511 1-003d: 1-003d supply dvdd not found, using dummy regulator
[    2.141627] adv7511 1-003d: 1-003d supply pvdd not found, using dummy regulator
[    2.148975] adv7511 1-003d: 1-003d supply a2vdd not found, using dummy regulator
[    2.156424] adv7511 1-003d: 1-003d supply v3p3 not found, using dummy regulator
[    2.163771] adv7511 1-003d: 1-003d supply v1p2 not found, using dummy regulator
[    2.172801] adv7511 1-003d: Probe failed. Remote port 'mipi_dsi@32e10000' disabled
[    2.184148] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@50
[    2.192238] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@50/connector
[    2.200964] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@50/connector
[    2.249007] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@52
[    2.257087] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@52/connector
[    2.265796] OF: graph: no port node found in /soc@0/bus@30800000/i2c@30a30000/tcpc@52/connector
[    2.277131] random: fast init done
power_bd71837_init
    Please help us solve the issue.
Thanks & Regards,
        Vasu
标签 (1)
3 回复数
2,310 次查看
2,305 次查看
Dhevan
Hi @igorpadykov
      Host tftp/nfs configured properly.
      Above mentioned error am getting but its seen like soc related error.
      If am boot from emmc there is no error.
Thanks & Regards,
         Vasu
2,302 次查看
for "imx/sdma/sdma-imx7d.bin failed with error -2" one can look at
https://community.nxp.com/t5/i-MX-Processors/Kernel-5-4-imx-6q-sdma-firmware-not-ready-SPI-transfer-...
Also one can try with latest L5.4.70_2.3.0
i.MX 8M Mini EVK
