[imx8m mini LPD4] how to flash kernel and dtb on uboot without uuu.
ソリューションへジャンプ
2,949件の閲覧回数
bryan_hong
Senior Contributor I
hello
I hate changing the dip switch SW1101 to use uuu every time I modify the kernel and build.
so I need to how to kernel flash on uboot mode.
thanks
Bryan
2,922件の閲覧回数
joanxie
you can use tftp to download images to the emmc, for more detailed steps, pls refer to the user guide
3 返答(返信)
2,946件の閲覧回数
joanxie
you can use dd command to download uboot, image and dtb file to the board, for more detailed information, pls refer to the chapter 4.3.4 Copying a bootloader image, 4.3.5 Copying the kernel image and DTB file and 4.3.6 Copying the root file system (rootfs)
2,944件の閲覧回数
bryan_hong
hello joanxie
I did not use sdcard.
when I use emmc, let me guide how to do flash without uuu.
thanks
Bryan
2,923件の閲覧回数
joanxie
