HI
I am using imx8dx, but my memory is only 512M, and I need to use QT.The memory is very tight, I want to close some unnecessary services, what should I do, such as closing ntpdate.service
thanks
$ sudo systemctl stop ntpdate.service $ sudo systemctl disable ntpdate.service
Zhiming
hi
Is there any other way? I want to close unneeded services before compiling.
For example, if there are any files, I only need to add unneeded services to close it before compiling.
thanks;
You mean delete it?
PACKAGECONFIG_remove = "xxxx"
What I mean is to prohibit the service during recompilation, so that no service will start when the system starts
hi,I am also trying to remove unused services before build in yocto.can you please help me?
