imx8dx yocto close some systemd service
2,485 次查看
songhongliang
HI
I am using imx8dx, but my memory is only 512M, and I need to use QT.
The memory is very tight, I want to close some unnecessary services, what should I do, such as closing ntpdate.service
thanks
5 回复数
2,481 次查看
Zhiming_Liu
$ sudo systemctl stop ntpdate.service
$ sudo systemctl disable ntpdate.service
Zhiming
2,476 次查看
songhongliang
hi
Is there any other way? I want to close unneeded services before compiling.
For example, if there are any files, I only need to add unneeded services to close it before compiling.
thanks;
2,474 次查看
Zhiming_Liu
You mean delete it?
PACKAGECONFIG_remove = "xxxx"
2,466 次查看
songhongliang
HI
What I mean is to prohibit the service during recompilation, so that no service will start when the system starts
thanks
2,120 次查看
jackk
hi,
I am also trying to remove unused services before build in yocto.can you please help me?
