imx8 Quad Max determine if SOM is closed by reading a fuse?
flobro
Is there a way to tell by a fuse or other way to determine id the "ahab_close" has been called?
I would like to do this in Linux if there is a fuse I can read.
Alternative, what user fuse is readable that I could set to use as an indicator if the closed status is not available?
Tags (5)
flobro
Without a Linux user space utility that could call SCFW, does not really help. I have  a workaround for our case that allows our manufacturing process the ability to mange the fuses.
Tags (3)
flobro
Response is great is you are using a terminal and a human is reading and acting upon it, so this is not a usable solution.
I could not use the "ahab_status" in a uboot "test" command to send the kernel the status in a command line argument (result code was not always correct "$?")
I do not understand why NXP could not use a readable fuse to indicate status just like imx8m Plus... There a so many unused fuses.
JosephAtNXP
Thank you for your patience,
The fuse is not readable from the user since the security differences from i.MX8MP (SECO and SCFW), there is a SCFW call that handles this and can help you (at U-boot, Linux, etc since it's a SCFW call). The life cycle is indeed a fuse but it's secured and you can read it though the API.
U-boot does it in the mentioned command. It's below, I hope it helps.
sc_err_t sc_seco_chip_info (sc_ipc_t ipc, uint16_t ∗lc, uint16_t ∗monotonic, uint32_t ∗uid_l, uint32_t ∗uid_h)
flobro
Tags (3)
flobro
Here is the situation: We cannot allow a SOM that is "not closed" to run code that is signed, intended for a closed device. That is a major security hole.
On the imx8M Plus, we could read a fuse to determine this and prevent the processor from booting, and report it as a security issue.
On the Quad Max, it does not appear that there is a way to determine this by reading a fuse (I hope I am wrong), but Uboot  reporting this does not help... If there was a "user fuse" (NXP refers to them as "Customer OTP fuses") that I can read in user space that can be burned by uboot the same time I close the SOM, that would work.
flobro
If there is a "Customer fuse" that can be read by the imx-scu-ocotp0 driver, that would work wonderfully...
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
You can confirm it in U-boot quickly with the command ahab_status.
%3CLINGO-SUB%20id%3D%22lingo-sub-2062186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIs%20there%20a%20way%20to%20tell%20by%20a%20fuse%20or%20other%20way%20to%20determine%20id%20the%20%22ahab_close%22%20has%20been%20called%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20would%20like%20to%20do%20this%20in%20Linux%20if%20there%20is%20a%20fuse%20I%20can%20read.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAlternative%2C%20what%20user%20fuse%20is%20readable%20that%20I%20could%20set%20to%20use%20as%20an%20indicator%20if%20the%20closed%20status%20is%20not%20available%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2062186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWithout%20a%20Linux%20user%20space%20utility%20that%20could%20call%20SCFW%2C%20does%20not%20really%20help.%20I%20have%26nbsp%3B%20a%20workaround%20for%20our%20case%20that%20allows%20our%20manufacturing%20process%20the%20ability%20to%20mange%20the%20fuses.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067471%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067471%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20patience%2C%3C%2FP%3E%0A%3CP%3EThe%20fuse%20is%20not%20readable%20from%20the%20user%20since%20the%20security%20differences%20from%20i.MX8MP%20(SECO%20and%20SCFW)%2C%20there%20is%20a%20SCFW%20call%20that%20handles%20this%20and%20can%20help%20you%20(at%20U-boot%2C%20Linux%2C%20etc%20since%20it's%20a%20SCFW%20call).%20The%20life%20cycle%20is%20indeed%20a%20fuse%20but%20it's%20secured%20and%20you%20can%20read%20it%20though%20the%20API.%3C%2FP%3E%0A%3CP%3EU-boot%20does%20it%20in%20the%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2Flf_v2022.04%2Fdrivers%2Fmisc%2Fimx8%2Fscu_api.c%23L980%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ementioned%20command%3C%2FA%3E.%20It's%20below%2C%20I%20hope%20it%20helps.%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Esc_err_t%20sc_seco_chip_info%20(sc_ipc_t%20ipc%2C%20uint16_t%20%E2%88%97lc%2C%20uint16_t%20%E2%88%97monotonic%2C%20uint32_t%20%E2%88%97uid_l%2C%20uint32_t%20%E2%88%97uid_h)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EResponse%20is%20great%20is%20you%20are%20using%20a%20terminal%20and%20a%20human%20is%20reading%20and%20acting%20upon%20it%2C%20so%20this%20is%20not%20a%20usable%20solution.%3C%2FP%3E%3CP%3EI%20could%20not%20use%20the%20%22ahab_status%22%20in%20a%20uboot%20%22test%22%20command%20to%20send%20the%20kernel%20the%20status%20in%20a%20command%20line%20argument%20(result%20code%20was%20not%20always%20correct%20%22%24%3F%22)%3C%2FP%3E%3CP%3EI%20do%20not%20understand%20why%20NXP%20could%20not%20use%20a%20readable%20fuse%20to%20indicate%20status%20just%20like%20imx8m%20Plus...%20There%20a%20so%20many%20unused%20fuses.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHere%20is%20the%20situation%3A%20We%20cannot%20allow%20a%20SOM%20that%20is%20%22not%20closed%22%20to%20run%20code%20that%20is%20signed%2C%20intended%20for%20a%20closed%20device.%20That%20is%20a%20major%20security%20hole.%3C%2FP%3E%3CP%3EOn%20the%20imx8M%20Plus%2C%20we%20could%20read%20a%20fuse%20to%20determine%20this%20and%20prevent%20the%20processor%20from%20booting%2C%20and%20report%20it%20as%20a%20security%20issue.%3C%2FP%3E%3CP%3EOn%20the%20Quad%20Max%2C%20it%20does%20not%20appear%20that%20there%20is%20a%20way%20to%20determine%20this%20by%20reading%20a%20fuse%20(I%20hope%20I%20am%20wrong)%2C%20but%20Uboot%26nbsp%3B%20reporting%20this%20does%20not%20help...%20If%20there%20was%20a%20%22user%20fuse%22%20(NXP%20refers%20to%20them%20as%20%22Customer%20OTP%20fuses%22)%20that%20I%20can%20read%20in%20user%20space%20that%20can%20be%20burned%20by%20uboot%20the%20same%20time%20I%20close%20the%20SOM%2C%20that%20would%20work.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20interest%20in%20NXP%20Semiconductor%20products%2C%3C%2FP%3E%0A%3CP%3EYou%20can%20confirm%20it%20in%20U-boot%20quickly%20with%20the%20command%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2F7376547b9e424b2d0f42dfe96394168c781ca297%2Fdoc%2Fimx%2Fahab%2Fguides%2Fmx8_mx8x_secure_boot.txt%23L266%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eahab_status%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20imx8%20Quad%20Max%20determine%20if%20SOM%20is%20closed%20by%20reading%20a%20fuse%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062214%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20there%20is%20a%20%22Customer%20fuse%22%20that%20can%20be%20read%20by%20the%26nbsp%3Bimx-scu-ocotp0%20driver%2C%20that%20would%20work%20wonderfully...%3C%2FP%3E%3C%2FLINGO-BODY%3E
