imx8: How to change kernel configuration of android12 for imx8mq target
vsuneja63
Thanks!
I could build & flash android12 image on imx8mq evk. I want to change kernel configuration for the android12 image, can you please guide me with the steps to modify & rebuild kernel for the same?
Can you please guide me with the path of default .config file also, i couldn't find .config in kernel build directory.
Bio_TICFSL
