imx7d: Rev D: FEC1 in u-boot for 4.1.15_2.0.0_ga release
4,287 次查看
skrishnakar
Hi igorpadykov‌,
I am looking for ENET2 i.e FEC1 initialization on i.MX7D Rev-D u-boot-imx-2016.03 that is from imx_4.1.15_2.0.0_ga release, but unfortunately I see I cannot switch the FEC via. ethact and it defaults to FEC0 only, but when kernel boots I can see both FEC0 and FEC1 are functional. Although the u-boot reports both MII devices but does not recognize the FEC1 while switching as shown below:
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Sep 15 2017 - 18:57:13 +0530)
CPU: Freescale i.MX7D rev1.2 996 MHz (running at 792 MHz)
CPU: Commercial temperature grade (0C to 95C) at 36C
Reset cause: POR
Board: i.MX7D SABRESD RevA
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
Display: TFT43AB (480x272)
Video: 480x272x24
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc0 is current device
Net: FEC0
Normal Boot
Hit any key to stop autoboot: 0
FEC1 test:
=> mii info
PHY 0x00: OUI = 0x180361, Model = 0x18, Rev = 0x09, 100baseT, FDX
PHY 0x01: OUI = 0x180361, Model = 0x18, Rev = 0x09, 10baseT, HDX
=> mii device
MII devices: 'FEC0'
Current device: 'FEC0'
=> printenv ethact
ethact=FEC0
=> setenv ethact FEC1
=> printenv ethact
ethact=FEC1
=> saveenv
Saving Environment to MMC...
Writing to MMC(0)... done
=> reset
resetting ...
CPU: Commercial temperature grade (0C to 95C) at 38C
Reset cause: POR
I2C: ready
DRAM: 1 GiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC0
Normal Boot
Is there a pin conflict due to which only FEC0 is set in the u-boot of imx7dsabresd ? Can you kindly confirm on availability of FEC1 (ENET2) at u-boot level for i.MX7D SabreSD Rev-D ? If at all this can enabled along with FEC0 without any other conflicts ?
Thanks in Advance!
-Srikant
3,570 次查看
igorpadykov
Hi Srikant
Rev-D changes:
code in mx7dsabresd.c which identifies board revision:
13 回复数
3,569 次查看
igorpadykov
Hi srikanth
please look at definition: #define CONFIG_FEC_ENET_DEV 0
in uboot/include/configs/mx7dsabresd.h
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/tree/include/configs/mx7dsabresd.h?h=imx_v20...
3,569 次查看
skrishnakar
Hello igorpadykov‌,
I have tried changing the "CONFIG_FEC_ENET_DEV 1", which builds fine and u-boot shows up, but it seems there is no effect in practical, as seen below:
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Sep 15 2017 - 20:02:21 +0530)
CPU: Commercial temperature grade (0C to 95C) at 39C
Reset cause: POR
I2C: ready
DRAM: 1 GiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Normal Boot
=> pri ethact
ethact=FEC1
=> mii device
MII devices: 'FEC1'
Current device: 'FEC1'
=> mii info
PHY 0x00: OUI = 0x180361, Model = 0x18, Rev = 0x09, 10baseT, HDX
PHY 0x01: OUI = 0x180361, Model = 0x18, Rev = 0x09, 100baseT, FDX
=> pri ipaddr
ipaddr=124.61.58.132
=> ping 124.61.58.100
Using FEC1 device
ARP Retry count exceeded; starting again
ping failed; host 124.61.58.100 is not alive
Is there anything that I am missing? Any extra setting or configuration need to be made here ?
Thanks!
-Srikant
3,569 次查看
igorpadykov
Hi Srikant
please try with settings in sect.4.4.1.1 attached Linux Guide.
3,569 次查看
skrishnakar
Hello igorpadykov‌,
If I try to set ethaddr manually, then u-boot complains of mismatch of mac address, thats read from SROM:
Net: FEC1
Warning: FEC1 MAC addresses don't match:
Address in SROM is 00:01:9f:04:90:ab
Address in environment is 00:01:02:03:04:05
Hence I continued the one that is read from fuse:
U-Boot 2016.03-imx_v2016.03_4.1.15_2.0.0_ga+g0ec2a01 (Sep 18 2017 - 15:56:41 +0530)
Reset cause: POR
I2C: ready
DRAM: 1 GiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Normal Boot
=> pri ethaddr
ethaddr=00:01:9f:04:90:ab
=> pri ipaddr
=> pri serverip
serverip=124.61.58.100
=> ping ${serverip}
Using FEC1 device
All the switch settings are intact and work fine for ENET0 (FEC0) on the same board. Neither I can ping the serverip nor I can ping to target from host (serverip).
Any pointers would be much appreciated here.
Srikant!
3,569 次查看
igorpadykov
Hi Srikant
please try direct connection to PC.
3,569 次查看
skrishnakar
Hi igorpadykov‌,
I have connected target to PC directly over cross-over Ethernet cable and manually set the ip addresses on host and it seems to have no effect in the behavior of FEC1 on imx7d:
CPU: Commercial temperature grade (0C to 95C) at 40C
Reset cause: POR
I2C: ready
DRAM: 1 GiB
Video: 480x272x24
In: serial
Out: serial
Err: serial
Net: FEC1
Normal Boot
=> pri ipaddr
ipaddr=192.168.1.10
=> pri serverip
serverip=192.168.1.100
=> ping ${serverip}
Using FEC1 device
ping failed; host 192.168.1.100 is not alive
Host loopback:
linux@mode:~$ ping 192.168.1.100
PING 192.168.1.100 (192.168.1.100) 56(84) bytes of data.
64 bytes from 192.168.1.100: icmp_seq=1 ttl=64 time=0.043 ms
64 bytes from 192.168.1.100: icmp_seq=2 ttl=64 time=0.038 ms
^C
--- 192.168.1.100 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 0.038/0.040/0.043/0.006 ms
linux@mode:~$
Host to target:
PING 192.168.1.10 (192.168.1.10) 56(84) bytes of data.
From 192.168.1.100 icmp_seq=1 Destination Host Unreachable
^C
--- 192.168.1.10 ping statistics ---
6 packets transmitted, 0 received, +1 errors, 100% packet loss, time 5098ms pipe 4
I have two IMX7D boards that behave identically. I have LS1021-A board too which has 3 ethernet ports and changing ethact was working there without any code change.
Thanks!
-Srikant
3,569 次查看
igorpadykov
Hi Srikant
from log: "i.MX7D SABRESD RevA" was used, while fec2 is used for board revisions
starting from rev.B according to comments in mx7dsabresd.c setup_iomux_fec() :
On RevB, GPIO1_IO04 is used for ENET2 EN..
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/tree/board/freescale/mx7dsabresd/mx7dsabresd...
3,567 次查看
skrishnakar
Hi igorpadykov‌,
This is actually a Rev-D board and same query was raised in my previous communications that despite of Rev-D specified on board the u-boot display the message as "Rev-A" because there is no conditional code in u-boot to show Rev-D see:
Line 275-277:
#define BOARD_REV_C  0x300 #define BOARD_REV_B  0x200 #define BOARD_REV_A  0x100
then Line 291-303:
     if (reg != 0) {           switch (reg >> 8 & 0x0F) {           case 0x3:                ret = BOARD_REV_C;                break;           case 0x02:                ret = BOARD_REV_B;                break;           case 0x01:           default:                ret = BOARD_REV_A;                break;           }
The Rev-D board defaults to Rev-A hence u-boot displays it as per the default case depicted above. Can you kindly confirm if I have misinterpreted the above setup ? My board has J36-J39 pins that were being referred while using EPDC panel.  Does this u-boot show Rev-D for all latest i.MX7D boards ?
Thanks a lot!
-Srikant
3,567 次查看
skrishnakar
Hello igorpadykov‌,
Can you confirm from the above picture whether the board that we are using is Rev-D or Rev-A ? Since all the code used for Rev-A is being used by the latest board even though it is considered as Rev-D ? These boards are dated 2016.
Srikant
3,569 次查看
igorpadykov
Hi Srikanth
on first page schematic there is description of changes rev.A vs D, one can check them:
Schematics (2)
Design files for i.MX 7Dual (REV D)
Design files, including hardware schematics, Gerbers, and OrCAD files for i.MX 7Dual (REV D)
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
one can try to change board settings so it was identified as "D" and used signal GPIO1_IO04 for ENET2 EN.
Please check this with oscilloscope.
3,569 次查看
skrishnakar
Hi igorpadykov‌,
I did look into the documents suggested by you and it depicts the EPDC/ENET2 configuration usage, but I couldn't find relevant instructions to change the hardware from Rev-A to Rev-D, the change-log of Rev-D does not reveal much to make a default board Rev-D.
If you don't mind, would you kindly point me to exact information that I am looking for in the schematics ? The ENET interrupt pin seems to be muxed with UART3 RXD as seen below:
Is that a jumper or switch setting which turns this board to Rev-D from Rev-A ?
Thanks for your patience!
Srikant
3,571 次查看
igorpadykov
Hi Srikant
Rev-D changes:
3,569 次查看
skrishnakar
Hi igorpadykov‌,
I was assuming there is a hardware setting or rework that would make it a permanent configuration hence I was asking for reference in schematics, but since you pointed back to u-boot board/machine file, I did the change in u-boot source i.e defaulting to Rev-C and changing the ENET device to 1 made it work:
Thanks a lot igorpadykov‌ for your continuous support on this. I hope I can use this as default setting on this board.
Srikant
