imx7 elcdif[mpu-mode] fifo data overflow size
810 次查看
hyuuma_sakamoto
I am using imx7 elcdif in MPU MODE (Mode86 / Data8Bit / Foramat8bit) I want to check the following monitoring at intervals, not for each data, but for what data at intervals Please tell me the size of the FIFO itself (LFIFO + INTFIFO + TXFIFO total or TXFIFO only?) ”The software will need to poll the FIFO STATUS bits to ensure that it does not overflow the eLCDIF data buffers. ”
1 回复
801 次查看
Yuri
@hyuuma_sakamoto
  in MPU Write Mode, TXFIFO (38x16) should not be overflowed, when
writing to LCDIF_DATA register.
Yuri.
