I am using UUU to flash my imx6ul starter kit with below script.
.\uuu.exe fb: ucmd setenv fastboot_buffer ${loadaddr}
.\uuu.exe fb: ucmd setenv forced_update 1
.\uuu.exe fb: download -f "u-boot-ccimx6ulstarter.imx"
.\uuu.exe "fb[-t 5000]": ucmd update uboot ram ${fastboot_buffer} ${fastboot_bytes}
.\uuu.exe FB: delay 1000
.\uuu.exe FB: ucmd nand erase.part rootfs
.\uuu.exe FB: ucmd setenv bootcmd "env default -a; saveenv; fastboot 0;"
.\uuu.exe FB: ucmd saveenv
.\uuu.exe FB: acmd reset
.\uuu.exe FB: delay 3000
.\uuu.exe FB: ucmd setenv fastboot_buffer ${loadaddr}
.\uuu.exe FB: download -f "core-image-minimal-ccimx6ulstarter.boot.ubifs"
.\uuu.exe "fb[-t 15000]": ucmd update "linux" ram ${fastboot_buffer} ${fastboot_bytes}
.\uuu.exe FB: download -f "core-image-minimal-ccimx6ulstarter.recovery.ubifs"
.\uuu.exe "fb[-t 15000]": ucmd update "recovery" ram ${fastboot_buffer} ${fastboot_bytes}
.\uuu.exe FB: download -f "core-image-minimal-ccimx6ulstarter.rootfs.ubifs"
.\uuu.exe "fb[-t 90000]": ucmd update "rootfs" ram ${fastboot_buffer} ${fastboot_bytes}
.\uuu.exe FB: ucmd nand erase.part update
.\uuu.exe FB: ucmd setenv boot_recovery yes
.\uuu.exe FB: ucmd setenv recovery_command wipe_update
It is working perfectly fine when I use it on evaluation board but it is not working on our custom board.
First part of the script before reset was working and when we reset the board for further commands USB is not getting detected after reset command. Hitting Error: Bulk(W):LIBUSB_ERROR_TIMEOUT error.
Script Logs:
C:\Users\H397427\Desktop\uuu_windows>uuu.bat
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe fb: ucmd setenv fastboot_buffer ${loadaddr}
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.4.165-0-ge10b026
Success 0 Failure 0
1:2 1/ 1 [ ] fb: ucmd setenv fastboot_buffer ${loadaddr}
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe fb: ucmd setenv forced_update 1
Success 0 Failure 0
1:2 1/ 1 [ ] fb: ucmd setenv forced_update 1
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe fb: download -f "u-boot-ccimx6ulstarter.imx"
Success 0 Failure 0
1:2 1/ 1 [ ] fb: download -f u-boot-ccimx6ulstarter.imx
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe "fb[-t 5000]": ucmd update uboot ram ${fastboot_buffer} ${fastboot_bytes}
Success 0 Failure 0
1:2 1/ 1 [ ] fb[-t 5000]: ucmd update uboot ram ${fastboot_buffer} ${fastboot_bytes}
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: delay 1000
Success 0 Failure 0
1:2 1/ 1 [ ] FB: delay 1000
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: ucmd nand erase.part rootfs
Success 0 Failure 0
1:2 1/ 1 [ ] FB: ucmd nand erase.part rootfs
Okay
Success 0 Failure 0
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: ucmd setenv bootcmd "env default -a; saveenv; fastboot 0;"
Success 0 Failure 0
1:2 1/ 1 [ ] FB: ucmd setenv bootcmd "env default -a; saveenv; fastboot 0;"
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: ucmd saveenv
Success 0 Failure 0
1:2 1/ 1 [ ] FB: ucmd saveenv
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: acmd reset
Success 0 Failure 0
1:2 1/ 1 [ ] FB: acmd reset
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: delay 3000
Success 0 Failure 0
1:2 1/ 1 [ ] FB: delay 3000
Okay
C:\Users\H397427\Desktop\uuu_windows>.\uuu.exe FB: ucmd setenv fastboot_buffer ${loadaddr}
Success 0 Failure 1
1:2 1/ 1 [Bulk(W):LIBUSB_ERROR_TIMEOUT ] FB: ucmd setenv fastboot_buffer ${loadaddr}
Serial Logs:
U-Boot dub-2020.04-r5.3+g463ba6ce56 (Dec 27 2021 - 10:58:25 +0000)
CPU: i.MX6UL rev1.2 528 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 33C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
MCA: HW_VER=1 FW_VER=1.14
force_idle_bus: sda=0 scl=0 sda.gp=0x1 scl.gp=0x0
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
NAND: 256 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Digi International ConnectCore 6UL Starter Board.
ConnectCore 6UL SOM variant 0x06: Industrial Ultralite 528MHz, 256MB NAND, 256MB DDR3, -40/+85C, Wireless, Bluetooth
Board version undefined, ID undefined
Boot device: NAND
Net: FEC0 MXC: board_eth_init:failed
No ethernet found.
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
=> fastboot 0
Starting download of 719872 bytes
downloading of 719872 bytes finished
Writing bootstream...OK
NAND erase.part: device 0 offset 0x1f00000, size 0x7a00000
Erasing at 0x98e0000 -- 100% complete.
OK
Saving Environment to NAND... Erasing redundant NAND...
Erasing at 0x320000 -- 100% complete.
Writing to redundant NAND... OK
OK
resetting ...
CPU: Industrial temperature grade (-40C to 105C) at 37C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Boot device: NAND
No ethernet found.
Fastboot: Normal
Normal Boot
*** Warning - ## Resetting to default environment
, using default environment
Saving Environment to NAND... Erasing NAND...
Erasing at 0x300000 -- 100% complete.
Writing to NAND... OK
OK
