imx6ull cannot blow SRK fuse
LoongX
    I want to use secure boot and consult the relevant documentation. The tutorial says to just enter the command, but an error occurs when I enter it.
MX6ULL > fuse prog 3 0 0x1431D1EF
Programming bank 3 word 0x00000000 to 0x1431d1ef...
Warning: Programming fuses is an irreversible operation!
This may brick your system.
Use this command only if you are sure of what you are doing!
Really perform this fuse programming? <y/N>
y
mxc_ocotp fuse_prog(): Access protect error
ERROR
Tags (2)
Harvey021
Please try to check if the SRK_LOCK is fused.
and try to read what the current value it is.
Harvey
