imx6ull MCIMX6Y7DVM09AB chip ethernet not work
chenfeng2016
Hello, about imx6ull, I have a question about Ethernet  need your help
In our project, when using imx6ull MCIMX6Y2CVM08AB chip, the ethernet  network can work normally.  you can see eth0 and eth1, by  ifconf -a ,but  the same hardware is replaced with imx6ull chip to MCIMX6Y7DVM09AB, the Ethernet network does not work, and eth0 or eth1 cannot be seen by  ifconfig -a
Help to analyze the causes, thanks
 MCIMX6Y2CVM08AB and MCIMX6Y7DVM09AB boot log attached.
Rita_Wang
The two chip have some difference,the MCIMX6Y7DVM09AB only support one Ethernet, and the MCIMX6Y2CVM08AB  support Ethernet x2.
