imx6ul-evk can no longer ping host
Search instead for
charlieschultz
I've been using an imx6ul-evk for a while now with a direct ethernet connection to a host pc (running NFS). Suddenly it seems the TFTP stopped working and I can no longer ping the host successfully (I get "error frame" messages). AFAIK nothing changed- any suggestions on what the problem might be?
Hi Charlie
to narrow down which side (EVK or host computer) has problem
one can try other EVK or computer and follow sect.4.4.1.1 Downloading an image to MMC/SD
attached User Guide to configure the U-Boot environment for network communications.
