imx6ul bitbake fsl-image-qt5
luoyaojun
yocto中指定imx6ul平台使用bitbake fsl-image-qt5生成的文件系统有1.3G大小? 如何删减除QT5外不必要的软件包?
另外:
core-image-x11、fsl-image-gui都不是用的QT吗?
我可以bitbake core-mage-base 然后在IMAGE_INSTALL_append += " qt4" 把qt4的环境放到文件系统中吗?
Labels (2)
karangajjar
Senior Contributor II
Hi luo yaojun,
You can find the packages that will be installed for an image by using below commands:
bitbake -g <image>
So, you can filter out the packages you do not want to install and remove them using PACKAGE_EXCLUDE command as in the link Yocto Project Reference Manual .
Also, you can follow Useful bitbake commands  for other useful bitbake commands.
Or
You can follow the below document to include qt in your image:
Building Qt5 using yocto on Wandboard - Wandboard Wiki
Karan Gajjar
karangajjar
Hi luo yaojun,
bitbake -g <image>
Or
Karan Gajjar
