imx6ul程序烧写
imx6ul程序烧写
1,175 次查看
wangqz2010
哪位大侠能够帮帮忙,我在用OTG烧写程序的时候,能够识别OTG,但无法下载程序,不知哪里出了问题?(板子是自己按照开发板画的。)谢谢了!
标记 (1)
1,023 次查看
lance_lau
你最后解决了没有,怎么解决的?我现在也遇到不能下载的问题。
1,023 次查看
jimmychan
Are you using MFGtool?
What is the different between your board and evk board?
Have you modify the u-boot and kernel base on the different on your board?
If you are using mfgtool, have you generate a new firmware for your board?
Is there a debug console output from your board? any log message and where is it stopped?
1,023 次查看
wangqz2010
Hello, thanks for your reply.
Yes I use the MFGtool to download the programs, but my board is a little different from the evk board.
I have not modify the U-boot and kernel, and haven't generate a new firmware for the board.
I am now looking for the reason from the hardware circuit.
BEST REGARDS
