Hi Prabhat
>In imx6UL, is watchdog (WDOGx_B / WDOG_ANY) enabled by default or need to be enable in software?
yes it should be enabled in software. Also in Serial Downloader mode it can be enabled by
fuse WDOG Timeout Select, this is described in Chapter 8 System Boot Reference Manual.
