imx6solo u-boot porting from nandflash
1,377件の閲覧回数
luchengxu
imx6solo u-boot porting from nandflash starting ,what need to modify the configuration,how to modify nand driver in the uboot source code?
ラベル(2)
1,246件の閲覧回数
please refer to attached Porting Guide Chapter 1 Porting U-Boot,
no changes are needed for booting from nand, just use mfg tools (with script
mfgtool2-yocto-mx-sabreauto-nand.vbs) on below link for programming uboot to nand
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
patch for U-Boot that integrates NXP kobs utility into U-Boot:
https://patchwork.ozlabs.org/patch/637573/
