imx6solo u-boot porting from nandflash
1,398 次查看
luchengxu
imx6solo u-boot porting from nandflash starting ,what need to modify the configuration,how to modify nand driver in the uboot source code?
标签 (2)
1,267 次查看
igorpadykov
please refer to attached Porting Guide Chapter 1 Porting U-Boot,
no changes are needed for booting from nand, just use mfg tools (with script
mfgtool2-yocto-mx-sabreauto-nand.vbs) on below link for programming uboot to nand
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/i.mx-applications-process...
patch for U-Boot that integrates NXP kobs utility into U-Boot:
https://patchwork.ozlabs.org/patch/637573/
