Hello
My board use MCIMX6L2EVN10AB no GPU ,no EPDC,it's hardware refer to offical board,the offical board use MCIMX6L8DVN10AB GPU and EPDC,i use sd boot,at offical board can normal work ,but at my board not work ,i use code from Freescale Public GIT, uboot version is 201504, kernel version is 3.14.28,i doubt is devicetree and kernel have support for GPU and EPDC,but my board not support,but i don't know modify where.could you give me some advices or give me some documents.
Thanks.
已解决! 转到解答。
Yes, you have to disable the support for GPU and EPDC in menuconfig before building the image for your GPU-less and EPDC-less part. Refer to the bottom of the Chapters 10 and 13 of the attached document for the information on the menuconfig options, available for EPDC and GPU modules.
Artur
Artur
