imx6sl 中断导致的死机
imx6sl 中断导致的死机
3,421件の閲覧回数
张松源
遇到一个死机问题, 我把很多模块的驱动都摘除了, 整机耗电电流在15mA左右,有时候会突然跳到40多mA,然后再恢复到15mA, 差不多一段时间过后就死机了,kernel没有什么log可看到,这时候耗电就在40多mA   有什么地方会导致电流突然跳变到40多mA的呢?
我机器连着串口线,每次串口输入命令,耗电也在40多mA左右,猜测是中断导致的这个耗电?
这样猜测对么?有什么解决问题的建议?
(ps:运行的是android系统。)
タグ(1)
5 返答(返信)
3,087件の閲覧回数
jimmychan
It is very hard to guess. You need to use the tools to check the running performance. e.g. Trace32 from Lauterbach or debugger/probe from GreenHills.
3,087件の閲覧回数
张松源
HI jimmychan
I don't know what is "Trace32 from Lauterbach or debugger/probe from GreenHills" mean,
what tools do you think I should use?
3,087件の閲覧回数
jimmychan
You can find the tools from here:
i.MX6SL|i.MX 6SoloLite Processors|Wearables|NXP
3,087件の閲覧回数
张松源
HI jimmychan
Thank you, could you just tell me which tools is using to check the running performance, I'm not good at finding these resource.
Best regards!
3,087件の閲覧回数
jimmychan
I didn't use this kind of tools because we don't write the application. You may contact the tool's company to get more details information.
