imx6sl 中断导致的死机
imx6sl 中断导致的死机
张松源
遇到一个死机问题, 我把很多模块的驱动都摘除了, 整机耗电电流在15mA左右,有时候会突然跳到40多mA,然后再恢复到15mA, 差不多一段时间过后就死机了,kernel没有什么log可看到,这时候耗电就在40多mA   有什么地方会导致电流突然跳变到40多mA的呢?
我机器连着串口线,每次串口输入命令,耗电也在40多mA左右,猜测是中断导致的这个耗电?
这样猜测对么?有什么解决问题的建议?
(ps:运行的是android系统。)
jimmychan
It is very hard to guess. You need to use the tools to check the running performance. e.g. Trace32 from Lauterbach or debugger/probe from GreenHills.
张松源
HI jimmychan
I don't know what is "Trace32 from Lauterbach or debugger/probe from GreenHills" mean,
what tools do you think I should use?
jimmychan
You can find the tools from here:
i.MX6SL|i.MX 6SoloLite Processors|Wearables|NXP
张松源
HI jimmychan
Thank you, could you just tell me which tools is using to check the running performance, I'm not good at finding these resource.
Best regards!
jimmychan
I didn't use this kind of tools because we don't write the application. You may contact the tool's company to get more details information.
