imx6qpsabresd how to build a helloworld.c
1,399 次查看
vividchloe
hi:
    I have installed the toolchain and tried to build my first helloworld.c,but it came out an error that "cann't find the stdio.h". could you give me some addvice to solve the problem?
the order which I used was "arm-poky-linux-gnueabi-gcc helloworld.c -o helloworld_sample"
the yocto system in ubuntu 64-bit was used
and would you know where the target lib and include is or is there a guide about how to make an app in the board?
Thanks!
标签 (2)
1,143 次查看
Yuri
  Please look at the following
https://community.nxp.com/thread/394804
Setting up the Eclipse IDE for Yocto Application Development
Yuri
1,143 次查看
vividchloe
Thank you!! it does work! The problem has solved
