Hi,all
I configure imx6qp with g2d can display two screen normal in weston clone mode. like below:
# /etc/init.d/weston stop
# weston --tty=1 --use-g2d=1 --device=/dev/fb0,/dev/fb2 --clone-mode --log=/var/log/weston.log
I found if I configure weston two screen display with g2d ,first will found blue screen ,later display the weston lauch.
And the weston cannot lockscreen and standby.
If I configure weston single screen display with gl,the --idle-time=300,default 5min,start the weston ,first is black screen,later is display the weston lauch.5minute later will lockscreen,screen off .
Why configure weston display with g2d,first start the weston will found blue screen,not black screen,this is not good for me.And configure idle-time is not valid.
Anyone can help me solve this problem or give me some advices?
Leo
Hello Leo,
Did you resolved this issue? I see this question as assumed answered but I wanted to double check and if you solved this issue it would benefit our communities if you could share your findings.
