我们是用imx6dl芯片做的一款Android手机,现在Power key是和ONOFF pin接在一起的,所以长按Power键可以实现5s强制关机,但是我们客户要求去掉这个功能,请问软件上能关掉这个功能吗?
谢谢
Jesse Lee
Solved! Go to Solution.
according to the Reference Manual, the ONOFF pin is:
Button presses greater than 5 seconds, when the SoC is powered, results in a direct hardware power down request signal to the power IC without providing a software interrupt first. This long button press initiates a hardware-enforced mode which is applicable when software is unable to power Off the device.
请问软件上能关掉这个功能吗? the answer is no.
