您好,我用一块linux开发板,处理器Imx6q的处理器,linux内核是4.1.15,使用到ECSPI2进行spid传输,现需要将ECSPI2设置为从站模式(slave mode),我应该操作哪些寄存器?以及在内核中如何查找到这些寄存器?有没有相似的例程或者链接?
Hi 留杰 付,
You can configure ECSPI2 in slave mode by configuring CHANNEL_MODE (specifically CHANNEL MODE[2] is for SPI channel 2 to 0 (slave mode)) in Control Register (ECSPIx_CONREG).
You can get above information from the imx6Q reference manual.
i.MX 6Quad Applications Processors | Quad Arm® Cortex®-A9 | NXP
Ankit Patel
