imx6q-sabrelite (bdsl) dtb i2c
2,551件の閲覧回数
shlomiperlman
HI,
im trying to register an i2c camera sensor and when i set the device in the dtb like this:
gc0309: gc0309@21 {
        compatible = "fsl,gc0309";
        reg = <0x21>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_gc0309>;
        clocks = <&clks 147>;
        clock-names = "csi_mclk";
        ipu_id = <1>;
        csi_id = <0>;
        mclk = <24000000>;
        mclk_source = <0>;
        clock-frequency = <100000>;
the device doesnt send i2c ACK.
if i don’t register the device then i can use the linux i2cset tool and get an ACK (successfully talk to the device).
also i'm setting :
pinctrl_gc0309: pinctrl_gc0309 {
            fsl,pins = <
                MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20     0x00000000     /* P3 - should always be 0 - enable gc0309 camera sensor on I2C1*/
                MX6QDL_PAD_SD1_DAT0__GPIO1_IO16         0x000b0     /* disable gc0309 camera sensor LED on I2C1.*/
                MX6QDL_PAD_GPIO_8__GPIO1_IO08         0x000b0     /*R5 - turn to 0(reset) -> turn to 1(normal)*/
I need to know how to select the ipu and csi properly, where is the clocks' list defined (currently 147 based on ov5642) and how to access these gpio's from the driver after they are initialized?
(as if to pull the reset up and down).
thanks !
ラベル(3)
タグ(3)
3 返答(返信)
416件の閲覧回数
RutvijTrivedi207
To your questions:
  1. /dev/video0 reads:
    No—v4l2_int_device does not read automatically from /dev/video0. The video node is created by the capture interface driver (CSI + bridge). Your camera driver just provides subdev ops. The CSI driver (e.g., imx-csi, mxc-mipi-csi2) is the one that pulls frames and exposes /dev/video0.
    So you should NOT open /dev/video0 inside the sensor driver. The V4L2 framework handles that.
  2. RGB pins / DT binding:
    Yes, you should describe the RGB (or YUV/RAW) bus in the device tree using the endpoint schema:
    • port@0 on the sensor (source)
    • port@1 on the CSI (sink)
      This includes bus-type, data-lanes or bus-width, polarities, etc.
      Without these DT endpoints, the subdev graph won’t link, and the CSI driver won’t start streaming.
  3. Examples:
    A clean reference for DT binding and endpoint structure is here,
    https://web.git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?id=773bb3066e6debf5b...
    & Driver for this - https://web.git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?id=fa9e6df636fb8b3b2...
  4. Further how to work with /dev/video nodes are very well explained here - https://siliconsignals.io/blog/v4l2-camera-stack-step-by-step-guide-for-custom-devices/
2,221件の閲覧回数
Hi shlomi
one can check i2c pinctlr settings, like pinctrl_i2c2_ov5642:
linux-imx6/imx6qdl-sabrelite.dtsi at boundary-imx_3.14.28_1.0.0_ga · boundarydevices/linux-imx6 · Gi...
main steps for camera integration are given in attached Porting Guide Chapter 7
Supporting the i.MX 6Dual/6Quad/6Solo/6DualLite Camera Sensor with CSI
2,221件の閲覧回数
shlomiperlman
thanks for the answer, it helped.
what i dont see is the read from /dev/video0 or the rgb lines in any of the references.
does the ioctl of the v4l2_int_device read automatically from /dev/video0 or should I open the dev from the driver myself to get the input?
is there an example of how to bind them (the rgb pins) in the dtb to the camera driver ? (is it necessary?)
thanks,
%3CLINGO-SUB%20id%3D%22lingo-sub-498857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimx6q-sabrelite%20(bdsl)%20dtb%20i2c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-498857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20i2c%20%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%20dtb%20%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Egc0309%3A%20gc0309%4021%20%7B%3C%2FP%3E%3CP%3E%E4%BA%92%E6%8F%9B%E6%80%A7%20%3D%20%22fsl%2Cgc0309%22%3B%3C%2FP%3E%3CP%3E%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%3D%26lt%3B0x21%26gt%3B%20!%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pinctrl-names%20%3D%20%22default%22%3B%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_gc0309%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%3D%20%26lt%3B%26amp%3Bclks%20147%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%20%3D%20%22csi_mclk%22%3B%3C%2FP%3E%3CP%3Eipu_id%20%3D%20%26lt%3B1%26gt%3B%3B%3C%2FP%3E%3CP%3Ecsi_id%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FP%3E%3CP%3Emclk%20%3D%20%26lt%3B24000000%26gt%3B%3B%3C%2FP%3E%3CP%3Emclk_source%20%3D%20%26lt%3B0%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B100000%26gt%3B%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%20i2c%20ACK%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81Linux%20i2cset%20%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20ACK%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E3%81%AB%E6%88%90%E5%8A%9F)%20%E3%82%92%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epinctrl_gc0309%3A%20pinctrl_gc0309%20%7B%3C%2FP%3E%3CP%3Efsl%E3%80%81%E3%83%94%E3%83%B3%20%3D%20%26lt%3B%20%3C%2FP%3E%3CP%3EMX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20%200x00000000%20%2F*%20P3%20-%20%E5%B8%B8%E3%81%AB%200%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20-%20I2C1%20%E3%81%A7%20gc0309%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%20*%2F%3C%2FP%3E%3CP%3EMX6QDL_PAD_SD1_DAT0__GPIO1_IO16%200x000b0%20%2F*%20I2C1%E3%81%AEgc0309%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5LED%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FP%3E%3CP%3EMX6QDL_PAD_GPIO_8__GPIO1_IO08%200x000b0%20%2F*R5%20-%200%E3%81%AB%E3%81%99%E3%82%8B(%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88)%20-%26gt%3B%201%E3%81%AB%E3%81%99%E3%82%8B(%E9%80%9A%E5%B8%B8)*%2F%20%3C%2FP%3E%3CP%3E%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eipu%20%E3%81%A8%20csi%20%E3%82%92%E9%81%A9%E5%88%87%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E6%89%80%20(%E7%8F%BE%E5%9C%A8%20ov5642%20%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%20147)%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%8C%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8B%E3%82%89%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%20gpio%20%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E(%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%B8%8A%E4%B8%8B%E3%81%AB%E5%BC%95%E3%81%A3%E5%BC%B5%E3%82%8B%E3%81%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-498857%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx6q-sabrelite%20(bdsl)%20dtb%20i2c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256408%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%B3%AA%E5%95%8F%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%2Fdev%2Fvideo0%20%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81v4l2_int_device%20%E3%81%AF%20%2Fdev%2Fvideo0%20%E3%81%8B%E3%82%89%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CEM%3E%E3%81%BE%E3%81%9B%E3%82%93%3C%2FEM%3E%E3%80%82%E3%83%93%E3%83%87%E3%82%AA%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20(CSI%20%2B%20%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8)%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%82%B5%E3%83%96%E9%96%8B%E7%99%BA%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%81%BF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSTRONG%3ECSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSTRONG%3E(%E4%BE%8B%3A%20imx-csi%E3%80%81mxc-mipi-csi2)%20%E3%81%AF%E3%80%81%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%92%E3%83%97%E3%83%AB%E3%81%97%E3%81%A6%20%2Fdev%2Fvideo0%20%E3%82%92%E5%85%AC%E9%96%8B%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%3CSTRONG%3E%E3%82%BB%E3%83%B3%E3%82%B5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%86%85%E3%81%A7%20%2Fdev%2Fvideo0%20%E3%82%92%E9%96%8B%E3%81%8B%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSTRONG%3E%E3%80%82V4L2%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%8C%E3%81%9D%E3%82%8C%E3%82%92%E5%87%A6%E7%90%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3ERGB%E3%83%94%E3%83%B3%2FDT%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%81%AF%E3%81%84%E3%80%81%3CSTRONG%3E%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%3C%2FSTRONG%3E%E3%82%B9%E3%82%AD%E3%83%BC%E3%83%9E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E5%86%85%E3%81%AE%20RGB%20(%E3%81%BE%E3%81%9F%E3%81%AF%20YUV%2FRAW)%20%E3%83%90%E3%82%B9%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%82%BB%E3%83%B3%E3%82%B5%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%400%EF%BC%88%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECSI%EF%BC%88%E3%82%B7%E3%83%B3%E3%82%AF%EF%BC%89%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%88%401%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81%E3%83%90%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%AC%E3%83%BC%E3%83%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%90%E3%82%B9%E5%B9%85%E3%80%81%E6%A5%B5%E6%80%A7%E3%81%AA%E3%81%A9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%20DT%20%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E3%82%B5%E3%83%96%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%82%B0%E3%83%A9%E3%83%95%E3%81%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%95%E3%82%8C%E3%81%9A%E3%80%81CSI%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E4%BE%8B%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%20DT%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A8%E3%82%A8%E3%83%B3%E3%83%89%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E6%A7%8B%E9%80%A0%E3%81%AE%E6%98%8E%E7%A2%BA%E3%81%AA%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%81%AF%E3%81%93%E3%81%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%3CA%20href%3D%22https%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3D773bb3066e6debf5b66ce598ec6a989911864d61%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3D773bb3066e6debf5b66ce598ec6a989911864d61%3C%2FA%3E%3CBR%20%2F%3E%26amp%3B%20%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20-%20%3CA%20href%3D%22https%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3Dfa9e6df636fb8b3b27570f38c53640c9e2b02f79%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fweb.git.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Fnext%2Flinux-next.git%2Fcommit%2F%3Fid%3Dfa9e6df636fb8b3b27570f38c53640c9e2b02f79%3C%2FA%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%2Fdev%2Fvideo%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AE%E6%93%8D%E4%BD%9C%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%A7%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20-%20%3CA%20href%3D%22https%3A%2F%2Fsiliconsignals.io%2Fblog%2Fv4l2-camera-stack-step-by-step-guide-for-custom-devices%2F%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fsiliconsignals.io%2Fblog%2Fv4l2-camera-stack-step-by-step-guide-for-custom-devices%2F%3C%2FA%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-498859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx6q-sabrelite%20(bdsl)%20dtb%20i2c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-498859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%80%81%2Fdev%2Fvideo0%20%E3%81%8B%E3%82%89%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%84%E3%80%81%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AE%E5%8F%82%E7%85%A7%E5%86%85%E3%81%AE%20RGB%20%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ev4l2_int_device%20%E3%81%AE%20ioctl%20%E3%81%AF%20%2Fdev%2Fvideo0%20%E3%81%8B%E3%82%89%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%85%A5%E5%8A%9B%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8B%E3%82%89%E8%87%AA%E5%88%86%E3%81%A7%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%96%8B%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edtb%20%E5%86%85%E3%81%AE%E3%81%9D%E3%82%8C%E3%82%89%20(rgb%20%E3%83%94%E3%83%B3)%20%E3%82%92%E3%82%AB%E3%83%A1%E3%83%A9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%83%90%E3%82%A4%E3%83%B3%E3%83%89%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AE%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%EF%BC%88%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%EF%BC%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-498858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx6q-sabrelite%20(bdsl)%20dtb%20i2c%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-498858%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epinctrl_i2c2_ov5642%20%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%20i2c%20pinctlr%20%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.14.28_1.0.0_ga%2Farch%2Farm%2Fboot%2Fdts%2Fimx6qdl-sabrelite.dtsi%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fboundarydevices%2Flinux-imx6%2Fblob%2Fboundary-imx_3.14.28_1.0.0_ga%2Farch%2Farm%2Fboot%2Fdts%2Fimx6qdl-sabrelite.dtsi%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elinux-imx6%2Fimx6qdl-sabrelite.dtsi%20at%20boundary-imx_3.14.28_1.0.0_ga%20%C2%B7%20boundarydevices%2Flinux-imx6%20%C2%B7%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%A1%E3%83%A9%E7%B5%B1%E5%90%88%E3%81%AE%E4%B8%BB%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AE%E7%AC%AC7%E7%AB%A0%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ECSI%20%E6%90%AD%E8%BC%89%E3%81%AE%20i.MX%206Dual%2F6Quad%2F6Solo%2F6DualLite%20%E3%82%AB%E3%83%A1%E3%83%A9%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A4%E3%82%B4%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E6%B3%A8%3A%20%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%B3%AA%E5%95%8F%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E6%AD%A3%E8%A7%A3%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%3CP%3E-----------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
