imx6q rstp stream and h264 decoding
2,416件の閲覧回数
ddejean
Hi everyone,
Our team is currently trying to play a RTSP stream with H264 encoded video with a Wandboard Quad running Android and we are facing some issues.
For information our wandboard quad is running the Freescale Kitkat 4.4 android port.
We first tried to diffuse with RTSP a 1080p movie (https://peach.blender.org/trailer-page/) using gstreamer (gst-rtsp-server-1.0/examples/test-mp4 ) on a computer and read it using the mediaframework on the wandboard and it worked perfectly.
Now we're trying to read a stream coming from a VLC rtsp server which casts the computer screen:
cvlc screen:// --screen-fps=30.000000 --screen-width=1920 --screen-height=1080 --live-caching=300 '--sout=#transcode{vcodec=h264,venc=x264{profile=high,preset=ultrafast,tune=zerolatency},fps=30,acodec=none}:rtp{sdp=rtsp://:8554/display}' --sout-keep
And we read it from a small android app which uses the media framework:
        mediaPlayer = new MediaPlayer();
        try {
            mediaPlayer.setDataSource(context, Uri.parse("rtsp://192.168.2.26:8554/display"));
            mediaPlayer.setOnPreparedListener(this);
            mediaPlayer.prepare();
            if (surface != null) {
                mediaPlayer.setSurface(surface);
            mediaPlayer.start();
        } catch (IOException e) {
            e.printStackTrace();
And the display stays black, there's no picture. Activating traces in the media framework we get the attached traces (see below or trace-1080p.txt attached file).
Then if we force VLC to scale to 720 it seems to work a bit better: ie we get an image, we don't have so much error traces but the display freezes after some time.
Does someone have any idea why we're not able to play this ? Any input/help would be welcome
V/MediaPlayer( 2445): constructor
V/MediaPlayer( 2445): setListener
D/MediaPlayer( 2445): Couldn't open file on client side, trying server side
V/MediaPlayer( 2445): setDataSource(rtsp://192.168.2.26:8554/display)
V/IMediaDeathNotifier( 2445): getMediaPlayerService
V/MediaPlayerService( 1436): Client(2) constructor
V/MediaPlayerService( 1436): Create new client(2) from pid 2445, uid 10045,
V/MediaPlayerService( 1436): setDataSource(rtsp://192.168.2.26:8554/display)
V/MediaPlayerService( 1436): player type = 4
V/AudioSink( 1436): AudioOutput(13)
V/NuPlayer( 1436): kWhatSetAudioSink
V/NuPlayer( 1436): kWhatSetDataSource
V/MediaPlayer( 2445): MediaPlayer::setAudioStreamType
V/MediaPlayer( 2445): setVideoSurfaceTexture
V/MediaPlayerService( 1436): [2] setVideoSurfaceTexture(0x0)
V/MediaPlayer( 2445): prepare
V/MediaPlayerService( 1436): [2] setAudioStreamType(3)
V/MediaPlayerService( 1436): [2] prepareAsync
V/MediaPlayerService( 1436): [2] notify (0x2c61dde0, 200, 701, 0)
V/MediaPlayer( 2445): message received msg=200, ext1=701, ext2=0
W/MediaPlayer( 2445): info/warning (701, 0)
V/MediaPlayer( 2445): callback application
V/MediaPlayer( 2445): back from callback
I/MyHandler( 1436): connection request completed with result 0 (Success)
V/ARTSPConnection( 1436): request: 'DESCRIBE rtsp://192.168.2.26:8554/display RTSP/1.0
V/ARTSPConnection( 1436): Accept: application/sdp
V/ARTSPConnection( 1436): User-Agent: stagefright/1.2 (Linux;Android 4.4.2)
V/ARTSPConnection( 1436): CSeq: 1
V/ARTSPConnection( 1436): '
I/ARTSPConnection( 1436): status: RTSP/1.0 200 OK
V/ARTSPConnection( 1436): line: 'Server: VLC/2.0.3'
V/ARTSPConnection( 1436): line: 'Date: Fri, 20 Mar 2015 12:31:42 GMT'
V/ARTSPConnection( 1436): line: 'Content-Type: application/sdp'
V/ARTSPConnection( 1436): line: 'Content-Base: rtsp://192.168.2.26:8554/display'
V/ARTSPConnection( 1436): line: 'Content-Length: 456'
V/ARTSPConnection( 1436): line: 'Cache-Control: no-cache'
V/ARTSPConnection( 1436): line: 'Cseq: 1'
I/MyHandler( 1436): DESCRIBE completed with result 0 (Success)
I/ASessionDescription( 1436): v=0
I/ASessionDescription( 1436): o=- 15615828936265859616 15615828936265859616 IN IP4 ddejean-dev1
V/ASessionDescription( 1436): adding 'o=' => '- 15615828936265859616 15615828936265859616 IN IP4 ddejean-dev1'
I/ASessionDescription( 1436): s=Unnamed
V/ASessionDescription( 1436): adding 's=' => 'Unnamed'
I/ASessionDescription( 1436): i=N/A
V/ASessionDescription( 1436): adding 'i=' => 'N/A'
I/ASessionDescription( 1436): c=IN IP4 0.0.0.0
V/ASessionDescription( 1436): adding 'c=' => 'IN IP4 0.0.0.0'
I/ASessionDescription( 1436): t=0 0
V/ASessionDescription( 1436): adding 't=' => '0 0'
I/ASessionDescription( 1436): a=tool:vlc 2.0.3
V/ASessionDescription( 1436): adding 'a=tool' => 'vlc 2.0.3'
I/ASessionDescription( 1436): a=recvonly
V/ASessionDescription( 1436): adding 'a=recvonly' => '(null)'
I/ASessionDescription( 1436): a=type:broadcast
V/ASessionDescription( 1436): adding 'a=type' => 'broadcast'
I/ASessionDescription( 1436): a=charset:UTF-8
V/ASessionDescription( 1436): adding 'a=charset' => 'UTF-8'
I/ASessionDescription( 1436): a=control:rtsp://192.168.2.26:8554/display
V/ASessionDescription( 1436): adding 'a=control' => 'rtsp://192.168.2.26:8554/display'
I/ASessionDescription( 1436): m=video 0 RTP/AVP 96
V/ASessionDescription( 1436): new section 'video 0 RTP/AVP 96'
I/ASessionDescription( 1436): b=RR:0
V/ASessionDescription( 1436): adding 'b=RR' => '0'
I/ASessionDescription( 1436): a=rtpmap:96 H264/90000
V/ASessionDescription( 1436): adding 'a=rtpmap:96' => 'H264/90000'
I/ASessionDescription( 1436): a=fmtp:96 packetization-mode=1;profile-level-id=42c028;sprop-parameter-sets=Z0LAKNoB4AiflwEQAAADABAAAAMDyPGDKg==,aM4PyA==;
V/ASessionDescription( 1436): adding 'a=fmtp:96' => 'packetization-mode=1;profile-level-id=42c028;sprop-parameter-sets=Z0LAKNoB4AiflwEQAAADABAAAAMDyPGDKg==,aM4PyA==;'
I/ASessionDescription( 1436): a=control:rtsp://192.168.2.26:8554/display/trackID=0
V/ASessionDescription( 1436): adding 'a=control' => 'rtsp://192.168.2.26:8554/display/trackID=0'
V/MyHandler( 1436): No duration found, assume live stream
V/avc_utils( 1436): frame_crop = (0, 0, 0, 4), cropUnitX = 2, cropUnitY = 2
V/avc_utils( 1436): sample aspect ratio = 1 : 1
I/APacketSource( 1436): dimensions 1920x1080
V/MyHandler( 1436): track #1 URL=rtsp://192.168.2.26:8554/display/trackID=0
V/ARTSPConnection( 1436): request: 'SETUP rtsp://192.168.2.26:8554/display/trackID=0 RTSP/1.0
V/ARTSPConnection( 1436): Transport: RTP/AVP/UDP;unicast;client_port=16538-16539
V/ARTSPConnection( 1436): CSeq: 2
V/ARTSPConnection( 1436): line: 'Transport: RTP/AVP/UDP;unicast;client_port=16538-16539;server_port=38481-38482;ssrc=38E2C772;mode=play'
V/ARTSPConnection( 1436): line: 'Session: 5714247c19670b2f;timeout=60'
V/ARTSPConnection( 1436): line: 'Content-Length: 0'
V/ARTSPConnection( 1436): line: 'Cseq: 2'
I/MyHandler( 1436): SETUP(1) completed with result 0 (Success)
I/MyHandler( 1436): server specified timeout of 60 secs.
W/MyHandler( 1436): Missing 'source' field in Transport response. Using RTSP endpoint address.
W/MyHandler( 1436): Server picked an odd RTP port, it should've picked an even one, we'll let it pass for now, but this may break in the future.
V/MyHandler( 1436): successfully poked holes.
V/ARTSPConnection( 1436): request: 'PLAY rtsp://192.168.2.26:8554/display RTSP/1.0
V/ARTSPConnection( 1436): Session: 5714247c19670b2f
V/ARTSPConnection( 1436): CSeq: 3
V/ARTPConnection( 1436): receiving RTP
V/AAVCAssembler( 1436): addSingleNALUnit of size 180
V/AAVCAssembler( 1436): addSingleNALUnit of size 227
V/AAVCAssembler( 1436): addSingleNALUnit of size 242
V/AAVCAssembler( 1436): addSingleNALUnit of size 168
V/AAVCAssembler( 1436): addSingleNALUnit of size 194
V/AAVCAssembler( 1436): addSingleNALUnit of size 166
V/AAVCAssembler( 1436): addSingleNALUnit of size 189
V/AAVCAssembler( 1436): addSingleNALUnit of size 266
V/ARTSPConnection( 1436): line: 'RTP-Info: url=rtsp://192.168.2.26:8554/display/trackID=0;seq=16099;rtptime=2754592522'
V/ARTSPConnection( 1436): line: 'Range: npt=41.485533-'
V/ARTSPConnection( 1436): line: 'Cseq: 3'
I/MyHandler( 1436): PLAY completed with result 0 (Success)
V/MyHandler( 1436): Range: npt=41.485533-
V/MyHandler( 1436): streamInfo[1] = url=rtsp://192.168.2.26:8554/display/trackID=0;seq=16099;rtptime=2754592522
V/MyHandler( 1436): track #1: rtpTime=2754592522 <=> npt=41.49
V/AAVCAssembler( 1436): addSingleNALUnit of size 23
V/AAVCAssembler( 1436): Access unit complete (8 nal units)
V/AAVCAssembler( 1436): addSingleNALUnit of size 14
V/OMX     ( 1436): OnEmptyBufferDone buffer=0x2bea7f00
V/ACodec  ( 1436): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] onOMXEmptyBufferDone 0x2bea7f00
V/ACodec  ( 1436): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] Needs to copy input data for buffer 0x2bea7f00. (0x2be7fe08 != 0x2bea7f90)
V/ACodec  ( 1436): [OMX.Freescale.std.video_decoder.avc.v3.hw-based] calling emptyBuffer 0x2bea7f00 w/ codec specific data
V/MyHandler( 1436): video track doesn't have enough data yet. (0.00 secs buffered)
V/AAVCAssembler( 1436): addSingleNALUnit of size 177
V/AAVCAssembler( 1436): addSingleNALUnit of size 243
V/AAVCAssembler( 1436): addSingleNALUnit of size 209
V/AAVCAssembler( 1436): addSingleNALUnit of size 137
V/AAVCAssembler( 1436): addSingleNALUnit of size 149
V/AAVCAssembler( 1436): addSingleNALUnit of size 188
V/AAVCAssembler( 1436): addSingleNALUnit of size 178
V/AAVCAssembler( 1436): addSingleNALUnit of size 252
V/MyHandler( 1436): onAccessUnitComplete track 0
V/MyHandler( 1436): storing accessUnit, no time established yet
V/AAVCAssembler( 1436): sequence length 1
V/AAVCAssembler( 1436): sequence length 2
V/AAVCAssembler( 1436): sequence length 3
V/AAVCAssembler( 1436): sequence length 4
V/AAVCAssembler( 1436): Not the sequence number I expected
V/AAVCAssembler( 1436): packetLost (expected 16299)
Original Attachment has been moved to: trace-1080p.txt.zip
ラベル(4)
0 返答(返信)
