imx6q rel_imx_3.10.17_1.0.2_ga gplay fps=0
peixiuhui
Hi, hello,When I use gplay play, FPS has been to 0, don't show, but a voice!Detailed information is as follows:
root@imx6qsabresd:~# gplay big_buck_bunny_1080p_h264.mov
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=big_buck_bunny_1080p_h264.mov
[Stopped  ][Vol=01][00:00:00/00:00:00][fps:0]Aiur: 3.0.11
Core: MPEG4PARSER_06.07.04  build on Dec  5 2013 11:41:38
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.2
Content Info:
        URI:
              file:///home/root/big_buck_bunny_1080p_h264.mov
        Idx File:
              /home/root/.aiur/.home.root.big_buck_bunny_1080p_h264.mov.aidx
        Seekable  : Yes
        Size(byte): 725106140
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:09:56.46169mxc_vpu 2040000.vpu: vpu_open()
6000
        ReadMode  : Tramxc_vpu 2040000.vpu: size=0x4000, page no.=0x2040
ck
        Track     : 3
mxc_vpu 2040000.vpu: start=0x7392c000, pgoff=0x3c200, size=0x7c000
Track 00 [video_000000] Enabled
        Duration:mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x4fe807
0:09:56.458304000
        Language: und
        Mime:
              video/x-h264, parsed=(boolean)true, width=(int)1920, height=(int)1080, framerate
              =(fraction)24/1
[INFO]  Product Info: i.MX6Q/D/S
vpudec versiomxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb5500000
ns :smileyhappy:
        plugin: 3.0.11mxc_vpu 2040000.vpu: start=0x73301000, pgoff=0x45500, size=0x4ff000
        wrapper: 1.0.46(VPUWRAPPER_ARM_LINUX Build on Apr 29 2015 15:42:10)
        vpulib: 5.4.23
        firmware: 3.1.1.46056
Track 01 [subtitle]: Disabled
        Codec: 0, SubCodec: 0
Track 02 [audio_000000] Enabled
        Duration: 0:09:56.480000000
        Language: und
        Mime:
              audio/mpeg, mpegversion=(int)4, channels=(int)6, rate=(int)48000, bitrate=(inmxcfb_ioctl
t)4
              48000, framxc_sdc_fb fb.23: Set color key to 0x00000818
med=(boolean)true, stream-format=(string)raw, codec_data=(buffer)11b0
FOUND GST_MESSAGE_TAG!
          codec: H.264/AVC
  language code: und
container format: MOV/MP4/3GP
    video codec: H.264/AVC
     frame rate: 24
    image width: 1920
   image height: 1080
          codec: AAC
  language code: und
        bitrate: 448000
MFW_GST_V4LSINK_PLUGIN 3.0.11 build on Apr 29 2015 21:10:59.
mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x94000
Beep: 3.0.11
Core: AAC decoder Wrapper  buimxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xac300000
ld on Jan 22 2014 15:42:53
  mimmxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x5fa000
e: audio/mpeg, mpegversion=(int){2,4}
  file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so.3
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00_CORTEX-A8  build on Sep 18 2013 10:29:53.
[INFO]  bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
number omxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb5a00000
f channels: 6
sampling frequencymxc_vpu 2040000.vpu: start=0x70a06000, pgoff=0x45a00, size=0x5fa000
(Hz): 48000
    audio codec: AAC decoder
    image width: 1920
   image height: 1080
minimum bitrate: 360005
maximum bitrate: 360005
minimum bitrate: 354755
minimum bitrate: 345755
minimum bitrate: 343130
maximum bitrate: 375755
Fmxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x2fd000
minimum bitrate: 341630
maximum bitrate: 387006
maximum bitrate: 429756
maximum bitrate: 431631
maximummxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6000000
bitrate: 437256
FOUND GST_MESSAmxc_vpu 2040000.vpu: start=0x6ff09000, pgoff=0x46000, size=0x2fd000
GE_TAG!
>>V4L_SINK: Actually buffer status:
        hardware buffer : 12
        software buffer : 0
maximum bitrate: 444006
maximumxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6300000
m bitrate: 458632
mxc_vpu 2040000.vpu: start=0x6fc0c000, pgoff=0x46300, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6600000
mxc_vpu 2040000.vpu: start=0x6f90f000, pgoff=0x46600, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6900000
mxc_vpu 2040000.vpu: start=0x6f612000, pgoff=0x46900, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6c00000
mxc_vpu 2040000.vpu: start=0x6f315000, pgoff=0x46c00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb6f00000
mxc_vpu 2040000.vpu: start=0x6f018000, pgoff=0x46f00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7200000
mxc_vpu 2040000.vpu: start=0x6ed1b000, pgoff=0x47200, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7500000
mxc_vpu 2040000.vpu: start=0x6ea1e000, pgoff=0x47500, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7800000
mxc_vpu 2040000.vpu: start=0x6e721000, pgoff=0x47800, size=0x2fd000
[Stopped  ][Vol=01][00:00:00/00:mxc_vpu 2040000.vpu: [ALLOC] mem alloc size = 0x2fd000
09:56][fps:0]mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7b00000
mxc_vpu 2040000.vpu: start=0x6e424000, pgoff=0x47b00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb7e00000
mxc_vpu 2040000.vpu: start=0x6e127000, pgoff=0x47e00, size=0x2fd000
mxc_vpu 2040000.vpu: [ALLOC] mem alloc cpu_addr = 0xb8100000
mxc_vpu 2040000.vpu: start=0x6de2a000, pgoff=0x48100, size=0x2fd000
mxc_vpu 2040000.vpu: vpu: memory phy:0x46000000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x461fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4627d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46600000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x467fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4687d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46c00000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46dfe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x46e7d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47200000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x473fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4747d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47800000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x479fe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47a7d800 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47e00000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x47ffe000 is phy memory
mxc_vpu 2040000.vpu: vpu: memory phy:0x4807d800 is phy memory
get GST_MESSAGE_ELEMENT prepare-xwindow-id;
get GST_MESSAGE_ELEMENT playbin2-stream-changed, uri=(string)file:///home/root/big_buck_bunny_1080p_h264.mov;
FOUNDmxcfb_ioctl
GST_MESSAGE_TAG!
maximum bitratmxc_sdc_fb fb.23: Set global alpha of DISP3 BG - DI1 to 0
e: 466507
maximum bitrate: 470632
maximum bitrate: 523133
[Stopped  ][Vol=01][00:00:00/00:09:56][fps:0]Wait status change from 2 to 4
fsl_player_play()
FSL_PLAYER_01.00_LINUX build on Apr 29 2015 21:11:52
        [h]display the operation Help
        [p]Play
        [s]Stop
        [e]Seek
        [a]Pause when playing, play when paused
        [v]Volume
        [m]Switch to mute or not
        [>]Play next file
        [<]Play previous file
        [r]Switch to repeated mode or not
        [f]Set full screen or not
        [z]resize the width and height
        [t]Rotate
        [c]Setting play rate
        [i]Display the metadata
        [x]eXit
[Playing  ][Vol=01][00:00:07/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 534008
[Playing  ][Vol=01][00:00:08/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 543383
maximum bitrate: 548258
[Playing  ][Vol=01][00:00:15/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 568133
[Playing  ][Vol=01][00:00:19/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 614634
[Playing  ][Vol=01][00:00:42/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 659260
[Playing  ][Vol=01][00:00:45/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 340505
[Playing  ][Vol=01][00:00:53/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 679510
maximum bitrate: 693010
[Playing  ][Vol=01][00:01:22/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 334130
minimum bitrate: 330380
minimum bitrate: 327380
minimum bitrate: 322130
minimum bitrate: 321380
minimum bitrate: 319129
minimum bitrate: 310129
minimum bitrate: 295879
minimum bitrate: 295504
[Playing  ][Vol=01][00:03:51/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
maximum bitrate: 750761
[Playing  ][Vol=01][00:04:56/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 290254
[Playing  ][Vol=01][00:04:57/00:09:56][fps:0]FOUND GST_MESSAGE_TAG!
minimum bitrate: 289879
Hope to get help,thank you.
gusarambula
I tested on the BSP Release 3.10.53 and gplay worked correctly for the same video. Are you still having problems? Are you using the BSP Release and not the FSL Community BSP (there are differences in codecs, for example). I would also make sure that the video is not corrupted, have you reproduced in other device?
