Hello!I created image,and the kernel version is 4.1.15.I use this command:DISTRO=fsl-imx-fb MACHINE=imx6qsabresd source fsl-setup-release.sh -b build-fb and bitbake fsl-image-qt5;And display changed to LCD(RGB888). I run the qt program,result as fllows.What should I do ?
You can refer to i.MX_Yocto_Project_User's_Guide.pdf
