Dear NXP
The NVCC_MIPI is recommended as 2.5V from datasheet. I have a camera that outputs 1.8V mipi signals. Can I directly connect those bus signal together? Is a voltage shifter needed? Thank you very much! Please refer the attachment for the mipi signals in schematic screen shot.
Jianxin
Solved! Go to Solution.
Hi Jianxin
please check Table 68. Electrical and Timing Information
in sect.4.12.12 MIPI D-PHY Timing Parameters i.MX6DQ Datasheet
http://www.nxp.com/docs/en/data-sheet/IMX6DQCEC.pdf
Hi Jianxin
