imx6q ext4 file system
2,862 次查看
yilingxu
Hi, my rootfs is put in SD card, and is not packaged, specifically, there are /bin, /boot, /dev, /user ... in my second partition of SD card. The linux kernel can mount this rootfs and it works well.
Now I want to sign my rootfs, so I want to make the rootfs as an image. Specifically, I want to make the rootfs as imx-imx6qsabresd.ext4, and put imx-imx6qsabresd.ext4 in my second partition of SD card. How can linux kernel work with this type of rootfs?
I am new with rootfs, can anyone give me some suggestions? thanks a lot.
Yiling Xu
标记 (1)
2,678 次查看
jimmychan
Are you talking about copying the root file system?
Attached is the Linux User's guide. please refer to the 4.3.5. for more details.
2,679 次查看
jimmychan
