imx6q 如何实现lvds和hdmi mirror显示,hdmi显示内容为lvds画面?
liuyue
jimmychan
Please read the i.MX_Linux_User's_Guide.pdf. You can download the pdf from here:
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
e.g. if you are using L4.1.15_2.1.0, then download the
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
