I have a custom board with imx6d working fine with linux & android (4.1.15 , 6.01 )
I have a fast splash screen on uboot , with the old display (1024x800 rgb24 single ch lvds) was ok, but with the new panel at 1920x1080 ( after some changes at setup_display function ) display the splash screen in dual channel lvds mode but the X resolution is 'virtual' , only 960 pixel are drawing in the lvds. The Y resolution is OK at 1080. Colors and bitmap image(dual width) is OK.
On uboot I could not make a proper debug of IPU registers. Please, someone can send an example of function to RW a IPUx register on uboot.
Solved! Go to Solution.
I have solved.
On split mode LDB_DIx_IPU_DIV on CCM_CSCMR2 must be the half ,(divider to 3,5)
On function setup_display_clock :
reg = readl(&mxc_ccm->cscmr2);
reg &=~(MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV | MXC_CCM_CSCMR2_LDB_DI1_IPU_DIV);
/* reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV | MXC_CCM_CSCMR2_LDB_DI1_IPU_DIV;
writel(reg, &mxc_ccm->cscmr2);
On function setup_display:
int reg;
reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES
|IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH
|IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW
|IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG
|IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG
#ifdef CONFIG_FORM_500
/* split_mode */
|IOMUXC_GPR2_DATA_WIDTH_CH1_24BIT
|IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT
|IOMUXC_GPR2_SPLIT_MODE_EN_MASK
|IOMUXC_GPR2_LVDS_CH1_MODE_ENABLED_DI0
#else
|IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT
|IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT
|IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED
#endif
|IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0;
writel(reg, &iomux->gpr[2]);
that's all.
I have solved.
int reg;
/* split_mode */
#else
#endif
that's all.
