I met issue with USB R/W in bootloader. the program try to read 512M each, sometime it will fail with EHCI timeout, sometime it will success. I want to know if BSP pass USB large file R/W test or not.
If you can give some advice, please let me know, thanks.
U-Boot 2015.04-g45172a2 (Apr 18 2018 - 13:58:32)f
CPU: Freescale i.MX6D rev1.5 at 792 MHz
CPU: Temperature 54 C
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 2 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
flash target is MMC:2
Fastboot: Normal
Net: Phy 1 not found
FEC [PRIME]
Error: FEC address not set.
starting USB...
USB0: USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
reading IMX6.bin
512 bytes read in 48 ms (9.8 KiB/s)
[UBOOT],200,77c00
[BOOTIMG],77e00,9c3800
[RECOVERY],a3b600,c26800
[SYSTEM],1661e00,1fc7b8b0
[VENDOR],212dd800,b6cb544
download uboot...
switch to partitions #1, OK
mmc2(part 1) is current device
MMC read: dev # 2, block # 0, count 2 ... 2 blocks read: OK
reading IMX6.bin
490496 bytes read in 92 ms (5.1 MiB/s)
MMC erase: dev # 2, block # 0, count 1024 ... 1024 blocks erased: OK
MMC write: dev # 2, block # 0, count 1024 ... 1024 blocks written: OK
download uboot success
switch to partitions #0, OK
mmc2(part 0) is current device
Partition Map for MMC device 2 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 16384 65536 00000000-01 83
2 81920 65536 00000000-02 83
3 147456 7024640 00000000-03 05 Extd
4 7172096 53899264 00000000-04 83
5 147457 3760127 00000000-05 83
6 3907585 1048575 00000000-06 83
7 4956161 16383 00000000-07 83
8 4972545 8191 00000000-08 83
9 4980737 4095 00000000-09 83
10 4984833 4095 00000000-0a 83
11 4988929 2047 00000000-0b 83
12 4990977 2047 00000000-0c 83
13 4993025 2097151 00000000-0d 83
download boot...
reading IMX6.bin
10237952 bytes read in 375 ms (26 MiB/s)
MMC erase: dev # 2, block # 16384, count 65536 ... 65536 blocks erased: OK
MMC write: dev # 2, block # 16384, count 65536 ... 65536 blocks written: OK
download boot success
download recovery...
reading IMX6.bin
12740608 bytes read in 462 ms (26.3 MiB/s)
MMC erase: dev # 2, block # 81920, count 65536 ... 65536 blocks erased: OK
MMC write: dev # 2, block # 81920, count 65536 ... 65536 blocks written: OK
download recovery success
download system...
MMC read: dev # 2, block # 147456, count 1 ... 1 blocks read: OK
MMC erase: dev # 2, block # 147456, count 3760128 ... 3760128 blocks erased: OK
MMC write: dev # 2, block # 147456, count 1 ... 1 blocks written: OK
download ...6%
reading IMX6.bin
EHCI timed out on TD - token=0x2c008d80
EHCI timed out on TD - token=0x9c008d80
EHCI timed out on TD - token=0x128d80
EHCI timed out on TD - token=0xce008d80
EHCI timed out on TD - token=0xcc008d80
EHCI timed out on TD - token=0xbc008d80
Error reading cluster
** Unable to read file IMX6.bin **
fatload usb 0 reserved system img failed
download vendor...
MMC read: dev # 2, block # 4993024, count 1 ... 1 blocks read: OK
MMC erase: dev # 2, block # 4993024, count 2097152 ... 2097152 blocks erased: OK
MMC write: dev # 2, block # 4993024, count 1 ... 1 blocks written: OK
download ...65%
EHCI timed out on TD - token=0x2008d80
** Can't read partition table on 0:0 **
** Invalid partition 1 **
fatload usb 0 reserved vendor img failed
download ...100%
Please plug out usb mass strorage, and reset the board
8
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 2 GiB
In: serial
Out: serial
Err: serial
Fastboot: Normal
FEC [PRIME]
starting USB...
USB0: USB EHCI 1.00
reading IMX6.bin
[UBOOT],200,77c00
download uboot...
reading IMX6.bin
490496 bytes read in 93 ms (5 MiB/s)
download boot...
reading IMX6.bin
10237952 bytes read in 390 ms (25 MiB/s)
reading IMX6.bin
12740608 bytes read in 478 ms (25.4 MiB/s)
download system...
download ...6%
reading IMX6.bin
533182640 bytes read in 16436 ms (30.9 MiB/s)
MMC write: dev # 2, block # 147457, count 1041372 ... 1041372 blocks written: OK
download ...60%
download vendor...
vendor img is not exist to be download
download ...100%
