imx6 yocto boost compilation fail on Ubuntu 14.04LTS
liguoqing
$ bitbake -vD -c compile -f
uild Configuration:
BB_VERSION        = "1.30.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6qsabresd"
DISTRO            = "fsl-imx-x11"
DISTRO_VERSION    = "4.1.15-2.1.0"
TUNE_FEATURES     = "arm armv7a vfp  neon        callconvention-hard        cortexa9"
TARGET_FPU        = "hard"
meta
meta-poky         = "HEAD:f5da2a5913319ad6ac2141438ba1aa17576326ab"
meta-oe
meta-multimedia   = "HEAD:247b1267bbe95719cd4877d2d3cfbaf2a2f4865a"
meta-fsl-arm      = "HEAD:be78894e4682f111575470fb23e51e6ba523508d"
meta-fsl-arm-extra = "HEAD:3dfb82fc7e703eae9891b3ffda0e9393701f2396"
meta-fsl-demos    = "HEAD:a165068f8a0d1cf29aabe4b4053f28be1c2aa492"
meta-bsp
meta-sdk          = "HEAD:823b26a67261270d2bf22d511e6190641a8a90cf"
meta-browser      = "HEAD:77736988073a5d90fcff9d0005c8477332ede387"
meta-gnome
meta-networking
meta-python
meta-filesystems  = "HEAD:247b1267bbe95719cd4877d2d3cfbaf2a2f4865a"
meta-qt5          = "HEAD:ccae79be69c5268df3b47e4e14cea0591c39a531"
NOTE: Preparing RunQueue
NOTE: Marking Active Tasks
NOTE: Pruned 2242 inactive tasks, 260 left
NOTE: Assign Weightings
NOTE: Compute totals (have 1 endpoint(s))
NOTE: Invalidate task do_compile, /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb
NOTE: Tainting hash to force rebuild of task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_compile
WARNING: /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb.do_compile is tainted from a forced run
DEBUG: Starting bitbake-worker
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_populate_sysroot which could be accelerated
DEBUG: Found task virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_populate_sysroot which could be accelerated
NOTE: Executing SetScene Tasks
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/patch.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:4)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/terminal.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/patch.bbclass:8)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/staging.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:5)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/mirrors.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:7)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/utils.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:8)
DEBUG: We can skip tasks [8, 15, 20, 24, 32, 39, 47, 57, 66, 73, 80, 87, 94, 101, 108, 115, 126, 133, 140, 147, 154, 161, 168, 172, 178, 186, 193, 200, 207, 214, 221, 228, 235, 242, 249, 256]
NOTE: Executing RunQueue Tasks
DEBUG: Considering 0 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_unpack): set([1])
DEBUG: Considering 1 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_patch): set([3])
DEBUG: Considering 2 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_fetch): set([0])
DEBUG: Considering 3 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_configure): set([4])
DEBUG: Considering 4 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_compile): set([])
DEBUG: Considering 5 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_unpack): set([6])
DEBUG: Considering 6 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_patch): set([10])
DEBUG: Considering 9 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_fetch): set([5])
DEBUG: Considering 10 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_configure): set([11])
DEBUG: Considering 12 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_unpack): set([13])
DEBUG: Considering 13 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_patch): set([17])
DEBUG: Considering 16 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_fetch): set([12])
DEBUG: Considering 17 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_configure): set([18])
DEBUG: Considering 21 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_configure): set([22])
DEBUG: Considering 25 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_configure): set([26])
DEBUG: Considering 27 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_unpack): set([28])
DEBUG: Considering 28 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_patch): set([34])
DEBUG: Considering 33 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_fetch): set([27])
DEBUG: Considering 34 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_configure): set([35])
DEBUG: Considering 36 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_unpack): set([37])
DEBUG: Considering 37 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_patch): set([41])
DEBUG: Considering 40 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_fetch): set([36])
DEBUG: Considering 41 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_configure): set([42])
DEBUG: Considering 43 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_unpack): set([44])
DEBUG: Considering 44 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_patch): set([49])
DEBUG: Considering 48 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_fetch): set([43])
DEBUG: Considering 49 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure): set([50, 51])
DEBUG: Considering 50 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure_ptest_base): set([51])
DEBUG: Considering 51 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_compile): set([52, 46])
DEBUG: Considering 53 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_unpack): set([54])
DEBUG: Considering 54 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_patch): set([59])
DEBUG: Considering 58 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_fetch): set([53])
DEBUG: Considering 59 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_configure): set([60, 61])
DEBUG: Considering 60 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_configure_ptest_base): set([61])
DEBUG: Considering 61 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_compile): set([56, 62])
DEBUG: Considering 63 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_unpack): set([64])
DEBUG: Considering 64 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_patch): set([68])
DEBUG: Considering 67 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_fetch): set([63])
DEBUG: Considering 68 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_configure): set([69])
DEBUG: Considering 70 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_unpack): set([71])
DEBUG: Considering 71 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_patch): set([75])
DEBUG: Considering 74 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_fetch): set([70])
DEBUG: Considering 75 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_configure): set([76])
DEBUG: Considering 77 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_unpack): set([78])
DEBUG: Considering 78 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_patch): set([82])
DEBUG: Considering 81 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_fetch): set([77])
DEBUG: Considering 82 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_configure): set([83])
DEBUG: Considering 84 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_unpack): set([85])
DEBUG: Considering 85 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_patch): set([89])
DEBUG: Considering 88 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_fetch): set([84])
DEBUG: Considering 89 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_configure): set([90])
DEBUG: Considering 91 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_unpack): set([92])
DEBUG: Considering 92 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_patch): set([96])
DEBUG: Considering 95 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_fetch): set([91])
DEBUG: Considering 96 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_configure): set([97])
DEBUG: Considering 98 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_unpack): set([99])
DEBUG: Considering 99 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_patch): set([103])
DEBUG: Considering 102 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_fetch): set([98])
DEBUG: Considering 103 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_configure): set([104])
DEBUG: Considering 105 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_unpack): set([106])
DEBUG: Considering 106 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_patch): set([110])
DEBUG: Considering 109 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_fetch): set([105])
DEBUG: Considering 110 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_configure): set([111])
DEBUG: Considering 112 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_unpack): set([113])
DEBUG: Considering 113 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_patch): set([117])
DEBUG: Considering 116 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_fetch): set([112])
DEBUG: Considering 117 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure): set([118])
DEBUG: Considering 119 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_unpack): set([120])
DEBUG: Considering 120 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_patch): set([122])
DEBUG: Considering 121 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_fetch): set([119])
DEBUG: Considering 122 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_preconfigure): set([25, 179, 21, 173, 169])
DEBUG: Considering 123 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_unpack): set([124])
DEBUG: Considering 124 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_patch): set([128])
DEBUG: Considering 127 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_fetch): set([123])
DEBUG: Considering 128 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_configure): set([129])
DEBUG: Considering 130 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_unpack): set([131])
DEBUG: Considering 131 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_patch): set([135])
DEBUG: Considering 134 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_fetch): set([130])
DEBUG: Considering 135 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_configure): set([136])
DEBUG: Considering 137 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_unpack): set([138])
DEBUG: Considering 138 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_patch): set([142])
DEBUG: Considering 141 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_fetch): set([137])
DEBUG: Considering 142 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_configure): set([143])
DEBUG: Considering 144 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_unpack): set([145])
DEBUG: Considering 145 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_patch): set([149])
DEBUG: Considering 148 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_fetch): set([144])
DEBUG: Considering 149 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_configure): set([150])
DEBUG: Considering 151 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_unpack): set([152])
DEBUG: Considering 152 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_patch): set([156])
DEBUG: Considering 155 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_fetch): set([151])
DEBUG: Considering 156 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_configure): set([157])
DEBUG: Considering 158 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_unpack): set([159])
DEBUG: Considering 159 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_patch): set([163])
DEBUG: Considering 162 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_fetch): set([158])
DEBUG: Considering 163 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_configure): set([164])
DEBUG: Considering 169 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_configure): set([170])
DEBUG: Considering 173 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_configure): set([174])
DEBUG: Considering 179 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_configure): set([180])
DEBUG: Considering 181 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_unpack): set([182])
DEBUG: Considering 182 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_patch): set([188])
DEBUG: Considering 187 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_fetch): set([181])
DEBUG: Considering 188 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_configure): set([189])
DEBUG: Considering 190 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_unpack): set([191])
DEBUG: Considering 191 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_patch): set([195])
DEBUG: Considering 194 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_fetch): set([190])
DEBUG: Considering 195 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_configure): set([196])
DEBUG: Considering 197 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_unpack): set([198])
DEBUG: Considering 198 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_patch): set([202])
DEBUG: Considering 201 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_fetch): set([197])
DEBUG: Considering 202 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_configure): set([203])
DEBUG: Considering 204 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_unpack): set([205])
DEBUG: Considering 205 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_patch): set([209])
DEBUG: Considering 208 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_fetch): set([204])
DEBUG: Considering 209 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_configure): set([210])
DEBUG: Considering 211 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_unpack): set([212])
DEBUG: Considering 212 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_patch): set([216])
DEBUG: Considering 215 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_fetch): set([211])
DEBUG: Considering 216 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_configure): set([217])
DEBUG: Considering 218 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_unpack): set([219])
DEBUG: Considering 219 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_patch): set([223])
DEBUG: Considering 222 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_fetch): set([218])
DEBUG: Considering 223 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_configure): set([224])
DEBUG: Considering 225 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_unpack): set([226])
DEBUG: Considering 226 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_patch): set([230])
DEBUG: Considering 229 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_fetch): set([225])
DEBUG: Considering 230 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_configure): set([231])
DEBUG: Considering 232 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_unpack): set([233])
DEBUG: Considering 233 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_patch): set([237])
DEBUG: Considering 236 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_fetch): set([232])
DEBUG: Considering 237 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_configure): set([238])
DEBUG: Considering 239 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_unpack): set([240])
DEBUG: Considering 240 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_patch): set([244])
DEBUG: Considering 243 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_fetch): set([239])
DEBUG: Considering 244 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_configure): set([245])
DEBUG: Considering 246 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_unpack): set([247])
DEBUG: Considering 247 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_patch): set([251])
DEBUG: Considering 250 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_fetch): set([246])
DEBUG: Considering 251 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_configure): set([252])
DEBUG: Considering 253 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_unpack): set([254])
DEBUG: Considering 254 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_patch): set([258])
DEBUG: Considering 257 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_fetch): set([253])
DEBUG: Considering 258 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_configure): set([259])
DEBUG: Skip list (pre setsceneverify) [5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259]
DEBUG: Full skip list set([5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259])
DEBUG: Using runqueue scheduler 'speed'
DEBUG: Marking task 5 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_unpack) as buildable
DEBUG: Marking task 6 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_patch) as buildable
DEBUG: Marking task 10 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_configure) as buildable
DEBUG: Marking task 11 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_compile) as buildable
DEBUG: Marking task 7 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_install) as buildable
DEBUG: Marking task 8 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.64.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 158 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_unpack) as buildable
DEBUG: Marking task 159 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_patch) as buildable
DEBUG: Marking task 163 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_configure) as buildable
DEBUG: Marking task 164 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_compile) as buildable
DEBUG: Marking task 160 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_install) as buildable
DEBUG: Marking task 161 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/texinfo-dummy-native/texinfo-dummy-native.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 98 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_unpack) as buildable
DEBUG: Marking task 99 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_patch) as buildable
DEBUG: Marking task 103 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_configure) as buildable
DEBUG: Marking task 104 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_compile) as buildable
DEBUG: Marking task 100 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_install) as buildable
DEBUG: Marking task 101 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gnu-config/gnu-config_git.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 232 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_unpack) as buildable
DEBUG: Marking task 233 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_patch) as buildable
DEBUG: Marking task 237 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_configure) as buildable
DEBUG: Marking task 238 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_compile) as buildable
DEBUG: Marking task 234 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_install) as buildable
DEBUG: Marking task 77 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_unpack) as buildable
DEBUG: Marking task 235 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/m4/m4-native_1.4.17.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 78 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_patch) as buildable
DEBUG: Marking task 82 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_configure) as buildable
DEBUG: Marking task 83 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_compile) as buildable
DEBUG: Marking task 79 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_install) as buildable
DEBUG: Marking task 80 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/autoconf/autoconf_2.69.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 84 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_unpack) as buildable
DEBUG: Marking task 85 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_patch) as buildable
DEBUG: Marking task 89 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_configure) as buildable
DEBUG: Marking task 90 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_compile) as buildable
DEBUG: Marking task 86 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_install) as buildable
DEBUG: Marking task 87 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/automake/automake_1.15.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 91 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_unpack) as buildable
DEBUG: Marking task 92 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_patch) as buildable
DEBUG: Marking task 96 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_configure) as buildable
DEBUG: Marking task 97 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_compile) as buildable
DEBUG: Marking task 93 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_install) as buildable
DEBUG: Marking task 94 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-native_2.4.6.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 105 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_unpack) as buildable
DEBUG: Marking task 106 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_patch) as buildable
DEBUG: Marking task 110 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_configure) as buildable
DEBUG: Marking task 111 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_compile) as buildable
DEBUG: Marking task 107 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_install) as buildable
DEBUG: Marking task 108 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/gettext/gettext-minimal-native_0.19.4.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 197 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_unpack) as buildable
DEBUG: Marking task 198 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_patch) as buildable
DEBUG: Marking task 202 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_configure) as buildable
DEBUG: Marking task 203 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_compile) as buildable
DEBUG: Marking task 199 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_install) as buildable
DEBUG: Marking task 200 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/xz/xz_5.2.2.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 144 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_unpack) as buildable
DEBUG: Marking task 145 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_patch) as buildable
DEBUG: Marking task 149 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_configure) as buildable
DEBUG: Marking task 150 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_compile) as buildable
DEBUG: Marking task 146 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_install) as buildable
DEBUG: Marking task 147 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/gmp/gmp_6.1.0.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 218 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_unpack) as buildable
DEBUG: Marking task 219 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_patch) as buildable
DEBUG: Marking task 223 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_configure) as buildable
DEBUG: Marking task 224 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_compile) as buildable
DEBUG: Marking task 220 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_install) as buildable
DEBUG: Marking task 221 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pkgconfig/pkgconfig_git.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 137 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_unpack) as buildable
DEBUG: Marking task 112 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_unpack) as buildable
DEBUG: Marking task 138 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_patch) as buildable
DEBUG: Marking task 113 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_patch) as buildable
DEBUG: Marking task 142 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_configure) as buildable
DEBUG: Marking task 117 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure) as buildable
DEBUG: Marking task 143 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_compile) as buildable
DEBUG: Marking task 118 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_compile) as buildable
DEBUG: Marking task 139 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_install) as buildable
DEBUG: Marking task 114 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_install) as buildable
DEBUG: Marking task 140 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/mpfr/mpfr_3.1.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 115 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 119 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_unpack) as buildable
DEBUG: Marking task 120 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_patch) as buildable
DEBUG: Marking task 122 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-source_5.3.bb, do_preconfigure) as buildable
DEBUG: Marking task 225 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_unpack) as buildable
DEBUG: Marking task 226 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_patch) as buildable
DEBUG: Marking task 230 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_configure) as buildable
DEBUG: Marking task 231 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_compile) as buildable
DEBUG: Marking task 227 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_install) as buildable
DEBUG: Marking task 70 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_unpack) as buildable
DEBUG: Marking task 63 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_unpack) as buildable
DEBUG: Marking task 228 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/ncurses/ncurses_6.0+20160213.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 71 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_patch) as buildable
DEBUG: Marking task 64 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_patch) as buildable
DEBUG: Marking task 75 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_configure) as buildable
DEBUG: Marking task 68 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_configure) as buildable
DEBUG: Marking task 76 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_compile) as buildable
DEBUG: Marking task 69 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_compile) as buildable
DEBUG: Marking task 72 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_install) as buildable
DEBUG: Marking task 65 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_install) as buildable
DEBUG: Marking task 12 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_unpack) as buildable
DEBUG: Marking task 73 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/attr/attr_2.4.47.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 66 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/sqlite/sqlite3_3.11.0.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 13 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_patch) as buildable
DEBUG: Marking task 17 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_configure) as buildable
DEBUG: Marking task 18 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_compile) as buildable
DEBUG: Marking task 14 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_install) as buildable
DEBUG: Marking task 15 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/pseudo/pseudo_1.7.5.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 246 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_unpack) as buildable
DEBUG: Marking task 239 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_unpack) as buildable
DEBUG: Marking task 247 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_patch) as buildable
DEBUG: Marking task 240 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_patch) as buildable
DEBUG: Marking task 251 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_configure) as buildable
DEBUG: Marking task 244 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_configure) as buildable
DEBUG: Marking task 252 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_compile) as buildable
DEBUG: Marking task 245 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_compile) as buildable
DEBUG: Marking task 248 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_install) as buildable
DEBUG: Marking task 241 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_install) as buildable
DEBUG: Marking task 151 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_unpack) as buildable
DEBUG: Marking task 123 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_unpack) as buildable
DEBUG: Marking task 249 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/bison/bison_3.0.4.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 242 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/flex/flex_2.6.0.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 152 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_patch) as buildable
DEBUG: Marking task 124 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_patch) as buildable
DEBUG: Marking task 156 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_configure) as buildable
DEBUG: Marking task 128 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_configure) as buildable
DEBUG: Marking task 157 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_compile) as buildable
DEBUG: Marking task 129 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_compile) as buildable
DEBUG: Marking task 153 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_install) as buildable
DEBUG: Marking task 125 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_install) as buildable
DEBUG: Marking task 154 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/libmpc/libmpc_1.0.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 126 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/binutils/binutils-cross_2.26.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 173 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_configure) as buildable
DEBUG: Marking task 174 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_compile) as buildable
DEBUG: Marking task 171 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_install) as buildable
DEBUG: Marking task 172 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross-initial_5.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 179 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_configure) as buildable
DEBUG: Marking task 180 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_compile) as buildable
DEBUG: Marking task 177 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_install) as buildable
DEBUG: Marking task 176 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_multilib_install) as buildable
DEBUG: Marking task 175 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_extra_symlinks) as buildable
DEBUG: Marking task 253 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_unpack) as buildable
DEBUG: Marking task 254 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_patch) as buildable
DEBUG: Marking task 258 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_configure) as buildable
DEBUG: Marking task 259 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_compile) as buildable
DEBUG: Marking task 255 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_install) as buildable
DEBUG: Marking task 130 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_unpack) as buildable
DEBUG: Marking task 256 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/unifdef/unifdef_2.11.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 131 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_patch) as buildable
DEBUG: Marking task 135 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_configure) as buildable
DEBUG: Marking task 136 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_compile) as buildable
DEBUG: Marking task 132 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_install) as buildable
DEBUG: Marking task 133 (/home/x/imx6/fsl-release-bsp/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux-libc-headers/linux-libc-headers_4.1.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 178 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc-initial_5.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 181 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_unpack) as buildable
DEBUG: Marking task 182 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_patch) as buildable
DEBUG: Marking task 188 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_configure) as buildable
DEBUG: Marking task 189 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_compile) as buildable
DEBUG: Marking task 185 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_install) as buildable
DEBUG: Marking task 184 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_install_locale) as buildable
DEBUG: Marking task 183 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_evacuate_scripts) as buildable
DEBUG: Marking task 190 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_unpack) as buildable
DEBUG: Marking task 191 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_patch) as buildable
DEBUG: Marking task 195 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_configure) as buildable
DEBUG: Marking task 196 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_compile) as buildable
DEBUG: Marking task 192 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_install) as buildable
DEBUG: Marking task 27 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_unpack) as buildable
DEBUG: Marking task 193 (virtual:native:/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/gperf/gperf_3.0.4.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 186 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc-initial_2.23.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 28 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_patch) as buildable
DEBUG: Marking task 34 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_configure) as buildable
DEBUG: Marking task 35 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_compile) as buildable
DEBUG: Marking task 31 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_install) as buildable
DEBUG: Marking task 29 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_evacuate_scripts) as buildable
DEBUG: Marking task 30 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_install_locale) as buildable
DEBUG: Marking task 32 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/glibc/glibc_2.23.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 21 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_configure) as buildable
DEBUG: Marking task 22 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_compile) as buildable
DEBUG: Marking task 19 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_install) as buildable
DEBUG: Marking task 20 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-cross_5.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 169 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_configure) as buildable
DEBUG: Marking task 170 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_compile) as buildable
DEBUG: Marking task 167 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_install) as buildable
DEBUG: Marking task 166 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_multilib_install) as buildable
DEBUG: Marking task 165 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_extra_symlinks) as buildable
DEBUG: Marking task 168 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/libgcc_5.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 25 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_configure) as buildable
DEBUG: Marking task 26 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_compile) as buildable
DEBUG: Marking task 23 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_install) as buildable
DEBUG: Marking task 24 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_5.3.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 211 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_unpack) as buildable
DEBUG: Marking task 204 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_unpack) as buildable
DEBUG: Marking task 212 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_patch) as buildable
DEBUG: Marking task 205 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_patch) as buildable
DEBUG: Marking task 216 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_configure) as buildable
DEBUG: Marking task 209 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_configure) as buildable
DEBUG: Marking task 217 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_compile) as buildable
DEBUG: Marking task 210 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_compile) as buildable
DEBUG: Marking task 213 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_install) as buildable
DEBUG: Marking task 206 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_install) as buildable
DEBUG: Marking task 53 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_unpack) as buildable
DEBUG: Marking task 43 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_unpack) as buildable
DEBUG: Marking task 214 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/opkg-utils/opkg-utils_git.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 207 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-devtools/libtool/libtool-cross_2.4.6.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 54 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_patch) as buildable
DEBUG: Marking task 44 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_patch) as buildable
DEBUG: Marking task 59 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_configure) as buildable
DEBUG: Marking task 49 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure) as buildable
DEBUG: Marking task 60 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_configure_ptest_base) as buildable
DEBUG: Marking task 50 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_configure_ptest_base) as buildable
DEBUG: Marking task 61 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_compile) as buildable
DEBUG: Marking task 51 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_compile) as buildable
DEBUG: Marking task 62 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_compile_ptest_base) as buildable
DEBUG: Marking task 52 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_compile_ptest_base) as buildable
DEBUG: Marking task 56 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_install) as buildable
DEBUG: Marking task 46 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_install) as buildable
DEBUG: Marking task 55 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_install_ptest_base) as buildable
DEBUG: Marking task 45 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_install_ptest_base) as buildable
DEBUG: Marking task 36 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_unpack) as buildable
DEBUG: Marking task 37 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_patch) as buildable
DEBUG: Marking task 41 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_configure) as buildable
DEBUG: Marking task 42 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_compile) as buildable
DEBUG: Marking task 38 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_install) as buildable
DEBUG: Marking task 0 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_unpack) as buildable
DEBUG: Marking task 57 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-extended/bzip2/bzip2_1.0.6.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 47 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-core/zlib/zlib_1.2.8.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 39 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/bjam-native_1.60.0.bb, do_populate_sysroot) as buildable
DEBUG: Marking task 1 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_patch) as buildable
DEBUG: Marking task 3 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_configure) as buildable
DEBUG: Marking task 4 (/home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb, do_compile) as buildable
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/utility-tasks.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:9)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/metadata_scm.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:10)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/logging.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/base.bbclass:11)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/meta-fsl-arm/classes/fsl-dynamic-packagearch.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta-poky/classes/poky-sanity.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package_rpm.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package_rpm.bbclass:1)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/packagedata.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package.bbclass:41)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/chrpath.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package.bbclass:42)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/insane.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/package.bbclass:45)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/buildstats.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/image-mklibs.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/linuxloader.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/image-mklibs.bbclass:5)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/debian.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/devshell.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/sstate.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/license.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/blacklist.bbclass (from configuration INHERITs:0)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/sanity.bbclass (from configuration INHERITs:0)
DEBUG: Using cache in '/home/x/imx6/fsl-release-bsp/build-x11/cache/bb_codeparser.dat'
DEBUG: Parsing /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost_1.60.0.bb (full)
DEBUG: Inheriting /home/x/imx6/fsl-release-bsp/sources/poky/meta/classes/python-dir.bbclass (from /home/x/imx6/fsl-release-bsp/sources/poky/meta/recipes-support/boost/boost.inc:31)
DEBUG: Executing task do_compile
Currently 1 running tasks (260 of 260):
0: boost-1.60.0-r0 do_compile (pid 8886)
boost-1.60.0-r0 do_compile: +
boost-1.60.0-r0 do_compile: cd
boost-1.60.0-r0 do_compile:  /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0
boost-1.60.0-r0 do_compile: do_compile
+ set -ex
+ rm -rf /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi
boost-1.60.0-r0 do_compile: + bjam -j2 -d+2 -q --ignore-site-config -sTOOLS=gcc -sGCC=arm-poky-linux-gnueabi-gcc  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9 -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed --sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd '-DBOOST_PLATFORM_CONFIG="boost/config/platform/linux-gnueabi.hpp"' -sGXX=arm-poky-linux-gnueabi-g++  -march=armv7-a -mfpu=neon  -mfloat-abi=hard -mcpu=cortex-a9 -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed --sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd '-DBOOST_PLATFORM_CONFIG="boost/config/platform/linux-gnueabi.hpp"' -sGCC_INCLUDE_DIRECTORY=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd/usr/include -sGCC_STDLIB_DIRECTORY=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd/usr/lib -sBUILD=release <optimization>space <threading>multi <inlining>on <debug-symbols>off -sPYTHON_ROOT=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd//usr --layout=system -sBOOST_BUILD_USER_CONFIG=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/user-config.jam --build-dir=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi --disable-icu --with-atomic --with-chrono --with-date_time --with-filesystem --with-graph --with-iostreams --with-log --with-program_options --with-random --with-regex --with-serialization --with-signals --with-system --with-timer --with-test --with-thread --prefix=/usr --exec-prefix=/usr --libdir=/usr/lib --includedir=/usr/include
boost-1.60.0-r0 do_compile: Performing configuration checks
    - 32-bit                   : yes
boost-1.60.0-r0 do_compile:     - arm                      : yes
Building the Boost C++ Libraries.
boost-1.60.0-r0 do_compile:     - symlinks supported       : yes
boost-1.60.0-r0 do_compile:     - has_icu builds           : no
boost-1.60.0-r0 do_compile:     - zlib                     : yes
boost-1.60.0-r0 do_compile:     - compiler-supports-visibility : yes
boost-1.60.0-r0 do_compile:     - lockfree boost::atomic_flag : yes
Component configuration:
    - atomic                   : building
    - chrono                   : building
    - container                : not building
    - context                  : not building
    - coroutine                : not building
    - coroutine2               : not building
    - date_time                : building
    - exception                : not building
    - filesystem               : building
    - graph                    : building
    - graph_parallel           : not building
boost-1.60.0-r0 do_compile:     - iostreams                : building
    - locale                   : not building
    - log                      : building
    - math                     : not building
    - mpi                      : not building
    - program_options          : building
    - python                   : not building
    - random                   : building
    - regex                    : building
    - serialization            : building
    - signals                  : building
    - system                   : building
    - test                     : building
    - thread                   : building
    - timer                    : building
    - type_erasure             : not building
    - wave                     : not building
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/lockpool.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_ATOMIC_SOURCE -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/lockpool.o" "libs/atomic/src/lockpool.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/libboost_atomic.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/libboost_atomic.so.1.60.0" -Wl,-h -Wl,libboost_atomic.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/lockpool.o"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_atomic.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/libboost_atomic.so.1.60.0"  "stage/lib/libboost_atomic.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_atomic.so
    ln -f -s 'libboost_atomic.so.1.60.0' 'stage/lib/libboost_atomic.so'
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/error_code.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/error_code.o" "libs/system/src/error_code.cpp"
In file included from libs/system/src/error_code.cpp:16:0:
./boost/system/error_code.hpp:221:36: warning: 'boost::system::posix_category' defined but not used [-Wunused-variable]
     static const error_category &  posix_category = generic_category();
./boost/system/error_code.hpp:222:36: warning: 'boost::system::errno_ecat' defined but not used [-Wunused-variable]
     static const error_category &  errno_ecat     = generic_category();
./boost/system/error_code.hpp:223:36: warning: 'boost::system::native_ecat' defined but not used [-Wunused-variable]
     static const error_category &  native_ecat    = system_category();
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0" -Wl,-h -Wl,libboost_system.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/error_code.o"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_system.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0"  "stage/lib/libboost_system.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_system.so
    ln -f -s 'libboost_system.so.1.60.0' 'stage/lib/libboost_system.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/chrono.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/chrono.o" "libs/chrono/src/chrono.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/thread_clock.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/thread_clock.o" "libs/chrono/src/thread_clock.cpp"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/process_cpu_clocks.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/process_cpu_clocks.o" "libs/chrono/src/process_cpu_clocks.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/libboost_chrono.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/libboost_chrono.so.1.60.0" -Wl,-h -Wl,libboost_chrono.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/chrono.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/thread_clock.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/process_cpu_clocks.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread -lrt -lpthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_chrono.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/libboost_chrono.so.1.60.0"  "stage/lib/libboost_chrono.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_chrono.so
    ln -f -s 'libboost_chrono.so.1.60.0' 'stage/lib/libboost_chrono.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_weekday.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DDATE_TIME_INLINE -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_weekday.o" "libs/date_time/src/gregorian/greg_weekday.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/date_generators.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DDATE_TIME_INLINE -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/date_generators.o" "libs/date_time/src/gregorian/date_generators.cpp"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/codecvt_error_category.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/codecvt_error_category.o" "libs/filesystem/src/codecvt_error_category.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_month.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_DYN_LINK=1 -DBOOST_ALL_NO_LIB=1 -DDATE_TIME_INLINE -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_month.o" "libs/date_time/src/gregorian/greg_month.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/libboost_date_time.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/libboost_date_time.so.1.60.0" -Wl,-h -Wl,libboost_date_time.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_month.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/greg_weekday.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/gregorian/date_generators.o"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_date_time.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/libboost_date_time.so.1.60.0"  "stage/lib/libboost_date_time.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_date_time.so
    ln -f -s 'libboost_date_time.so.1.60.0' 'stage/lib/libboost_date_time.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/operations.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/operations.o" "libs/filesystem/src/operations.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path_traits.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path_traits.o" "libs/filesystem/src/path_traits.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path.o" "libs/filesystem/src/path.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/portability.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/portability.o" "libs/filesystem/src/portability.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/unique_path.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/unique_path.o" "libs/filesystem/src/unique_path.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/utf8_codecvt_facet.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/utf8_codecvt_facet.o" "libs/filesystem/src/utf8_codecvt_facet.cpp"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/windows_file_codecvt.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/windows_file_codecvt.o" "libs/filesystem/src/windows_file_codecvt.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/libboost_filesystem.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/libboost_filesystem.so.1.60.0" -Wl,-h -Wl,libboost_filesystem.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/codecvt_error_category.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/operations.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/path_traits.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/portability.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/unique_path.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/utf8_codecvt_facet.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/windows_file_codecvt.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_filesystem.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/libboost_filesystem.so.1.60.0"  "stage/lib/libboost_filesystem.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_filesystem.so
    ln -f -s 'libboost_filesystem.so.1.60.0' 'stage/lib/libboost_filesystem.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cpp_regex_traits.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cpp_regex_traits.o" "libs/regex/build/../src/cpp_regex_traits.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/c_regex_traits.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/c_regex_traits.o" "libs/regex/build/../src/c_regex_traits.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/fileiter.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/fileiter.o" "libs/regex/build/../src/fileiter.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/icu.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/icu.o" "libs/regex/build/../src/icu.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cregex.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cregex.o" "libs/regex/build/../src/cregex.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/instances.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/instances.o" "libs/regex/build/../src/instances.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex.o" "libs/regex/build/../src/regex.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_debug.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_debug.o" "libs/regex/build/../src/regex_debug.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_raw_buffer.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_raw_buffer.o" "libs/regex/build/../src/regex_raw_buffer.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_traits_defaults.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_traits_defaults.o" "libs/regex/build/../src/regex_traits_defaults.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/static_mutex.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/static_mutex.o" "libs/regex/build/../src/static_mutex.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/w32_regex_traits.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/w32_regex_traits.o" "libs/regex/build/../src/w32_regex_traits.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wc_regex_traits.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wc_regex_traits.o" "libs/regex/build/../src/wc_regex_traits.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/posix_api.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/posix_api.o" "libs/regex/build/../src/posix_api.cpp"
Currently 1 running tasks (260 of 260):
0: boost-1.60.0-r0 do_compile (pid 8886)
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wide_posix_api.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wide_posix_api.o" "libs/regex/build/../src/wide_posix_api.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/usinstances.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/usinstances.o" "libs/regex/build/../src/usinstances.cpp"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/winstances.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_REGEX_DYN_LINK=1 -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/winstances.o" "libs/regex/build/../src/winstances.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/libboost_regex.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/libboost_regex.so.1.60.0" -Wl,-h -Wl,libboost_regex.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/c_regex_traits.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cpp_regex_traits.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/cregex.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/fileiter.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/icu.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/instances.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/posix_api.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_debug.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_raw_buffer.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/regex_traits_defaults.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/static_mutex.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/w32_regex_traits.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wc_regex_traits.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/wide_posix_api.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/winstances.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/usinstances.o"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_regex.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/libboost_regex.so.1.60.0"  "stage/lib/libboost_regex.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_regex.so
    ln -f -s 'libboost_regex.so.1.60.0' 'stage/lib/libboost_regex.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/read_graphviz_new.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_GRAPH_DYN_LINK=1 -DNDEBUG  -I"." -I"libs/graph/src" -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/read_graphviz_new.o" "libs/graph/src/read_graphviz_new.cpp"
In file included from ./boost/smart_ptr/detail/atomic_count.hpp:80:0,
                 from ./boost/detail/atomic_count.hpp:19,
                 from ./boost/xpressive/detail/utility/counted_base.hpp:12,
                 from ./boost/xpressive/detail/dynamic/matchable.hpp:22,
                 from ./boost/xpressive/detail/core/access.hpp:20,
                 from ./boost/xpressive/detail/core/state.hpp:18,
                 from ./boost/xpressive/detail/core/matcher/alternate_end_matcher.hpp:20,
                 from ./boost/xpressive/detail/core/matchers.hpp:17,
                 from ./boost/xpressive/regex_primitives.hpp:22,
                 from ./boost/xpressive/xpressive_static.hpp:24,
                 from ./boost/graph/graphviz.hpp:34,
                 from libs/graph/src/read_graphviz_new.cpp:50:
./boost/smart_ptr/detail/atomic_count_sync.hpp: In member function 'long int boost::detail::atomic_count::operator++()':
./boost/smart_ptr/detail/atomic_count_sync.hpp:49:5: warning: no return statement in function returning non-void [-Wreturn-type]
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/file_descriptor.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_IOSTREAMS_DYN_LINK=1 -DBOOST_IOSTREAMS_USE_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/file_descriptor.o" "libs/iostreams/src/file_descriptor.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/mapped_file.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_IOSTREAMS_DYN_LINK=1 -DBOOST_IOSTREAMS_USE_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/mapped_file.o" "libs/iostreams/src/mapped_file.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/bzip2.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_IOSTREAMS_DYN_LINK=1 -DBOOST_IOSTREAMS_USE_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/bzip2.o" "libs/iostreams/src/bzip2.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/gzip.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_IOSTREAMS_DYN_LINK=1 -DBOOST_IOSTREAMS_USE_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/gzip.o" "libs/iostreams/src/gzip.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/zlib.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_IOSTREAMS_DYN_LINK=1 -DBOOST_IOSTREAMS_USE_DEPRECATED -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/zlib.o" "libs/iostreams/src/zlib.cpp"
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/libboost_iostreams.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/libboost_iostreams.so.1.60.0" -Wl,-h -Wl,libboost_iostreams.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/file_descriptor.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/mapped_file.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/bzip2.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/gzip.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/zlib.o"  -Wl,-Bstatic  -Wl,-Bdynamic -lbz2 -lz -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_iostreams.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/iostreams/build/aca09349fdb84d131321425f6c3a38ed/libboost_iostreams.so.1.60.0"  "stage/lib/libboost_iostreams.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_iostreams.so
    ln -f -s 'libboost_iostreams.so.1.60.0' 'stage/lib/libboost_iostreams.so'
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/graphml.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC  -DBOOST_ALL_NO_LIB=1 -DBOOST_GRAPH_DYN_LINK=1 -DNDEBUG  -I"." -I"libs/graph/src" -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/graphml.o" "libs/graph/src/graphml.cpp"
                 from ./boost/graph/graphml.hpp:20,
                 from libs/graph/src/graphml.cpp:17:
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/libboost_graph.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/libboost_graph.so.1.60.0" -Wl,-h -Wl,libboost_graph.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/read_graphviz_new.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/graphml.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/libboost_regex.so.1.60.0"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_graph.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/graph/build/aca09349fdb84d131321425f6c3a38ed/libboost_graph.so.1.60.0"  "stage/lib/libboost_graph.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_graph.so
    ln -f -s 'libboost_graph.so.1.60.0' 'stage/lib/libboost_graph.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/once.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -Wno-unused-parameter -Wunused-function -pedantic -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO -DBOOST_THREAD_POSIX -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/once.o" "libs/thread/src/pthread/once.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/future.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -Wno-unused-parameter -Wunused-function -pedantic -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO -DBOOST_THREAD_POSIX -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/future.o" "libs/thread/src/future.cpp"
In file included from ./boost/thread/futures/future_error_code.hpp:13:0,
                 from libs/thread/src/future.cpp:10:
./boost/system/error_code.hpp:221:36: warning: 'boost::system::posix_category' defined but not used [-Wunused-variable]
     static const error_category &  posix_category = generic_category();
./boost/system/error_code.hpp:222:36: warning: 'boost::system::errno_ecat' defined but not used [-Wunused-variable]
     static const error_category &  errno_ecat     = generic_category();
./boost/system/error_code.hpp:223:36: warning: 'boost::system::native_ecat' defined but not used [-Wunused-variable]
     static const error_category &  native_ecat    = system_category();
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build"
boost-1.60.0-r0 do_compile: common.mkdir /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d
        mkdir -p "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_name.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_name.o" "libs/log/src/attribute_name.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_set.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_set.o" "libs/log/src/attribute_set.cpp"
                 from ./boost/smart_ptr/intrusive_ref_counter.hpp:19,
                 from ./boost/log/attributes/attribute.hpp:21,
                 from libs/log/src/attribute_set.cpp:22:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_value_set.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_value_set.o" "libs/log/src/attribute_value_set.cpp"
                 from ./boost/log/attributes/attribute_value.hpp:24,
                 from libs/log/src/attribute_value_set.cpp:24:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/code_conversion.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/code_conversion.o" "libs/log/src/code_conversion.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/thread.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pedantic -pthread -fPIC -Wextra -Wno-long-long -Wno-unused-parameter -Wunused-function -pedantic -DBOOST_ALL_NO_LIB=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO -DBOOST_THREAD_POSIX -DNDEBUG  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/thread.o" "libs/thread/src/pthread/thread.cpp"
In file included from ./boost/system/system_error.hpp:14:0,
                 from ./boost/thread/exceptions.hpp:22,
                 from ./boost/thread/pthread/thread_data.hpp:10,
                 from ./boost/thread/thread_only.hpp:17,
                 from libs/thread/src/pthread/thread.cpp:11:
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/libboost_thread.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/libboost_thread.so.1.60.0" -Wl,-h -Wl,libboost_thread.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/thread.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/pthread/once.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/future.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_thread.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/libboost_thread.so.1.60.0"  "stage/lib/libboost_thread.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_thread.so
    ln -f -s 'libboost_thread.so.1.60.0' 'stage/lib/libboost_thread.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/record_ostream.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/record_ostream.o" "libs/log/src/record_ostream.cpp"
                 from ./boost/log/attributes/attribute_value_set.hpp:26,
                 from ./boost/log/core/record.hpp:21,
                 from ./boost/log/sources/record_ostream.hpp:28,
                 from libs/log/src/record_ostream.cpp:18:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/core.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/core.o" "libs/log/src/core.cpp"
                 from ./boost/log/core/core.hpp:23,
                 from libs/log/src/core.cpp:32:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/severity_level.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/severity_level.o" "libs/log/src/severity_level.cpp"
                 from ./boost/log/sources/severity_feature.hpp:26,
                 from libs/log/src/severity_level.cpp:18:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope.o" "libs/log/src/named_scope.cpp"
                 from libs/log/src/named_scope.cpp:20:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/global_logger_storage.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/global_logger_storage.o" "libs/log/src/global_logger_storage.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_id.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_id.o" "libs/log/src/process_id.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_id.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_id.o" "libs/log/src/thread_id.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_name.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_name.o" "libs/log/src/process_name.cpp"
                 from ./boost/log/attributes/constant.hpp:23,
                 from ./boost/log/attributes/current_process_name.hpp:20,
                 from libs/log/src/process_name.cpp:21:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timer.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timer.o" "libs/log/src/timer.cpp"
                 from ./boost/log/attributes/timer.hpp:19,
                 from libs/log/src/timer.cpp:17:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_attribute_names.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_attribute_names.o" "libs/log/src/default_attribute_names.cpp"
Currently 1 running tasks (260 of 260):
0: boost-1.60.0-r0 do_compile (pid 8886)
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/exceptions.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/exceptions.o" "libs/log/src/exceptions.cpp"
                 from ./boost/log/attributes/named_scope.hpp:29,
                 from ./boost/log/support/exception.hpp:22,
                 from libs/log/src/exceptions.cpp:21:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_ostream_backend.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_ostream_backend.o" "libs/log/src/text_ostream_backend.cpp"
                 from ./boost/log/core/record_view.hpp:22,
                 from ./boost/log/sinks/basic_sink_backend.hpp:22,
                 from ./boost/log/sinks/text_ostream_backend.hpp:21,
                 from libs/log/src/text_ostream_backend.cpp:18:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_sink.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_sink.o" "libs/log/src/default_sink.cpp"
                 from ./boost/log/sinks/sink.hpp:22,
                 from libs/log/src/default_sink.hpp:20,
                 from libs/log/src/default_sink.cpp:27:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_multifile_backend.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_multifile_backend.o" "libs/log/src/text_multifile_backend.cpp"
                 from ./boost/log/sinks/text_multifile_backend.hpp:29,
                 from libs/log/src/text_multifile_backend.cpp:20:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/syslog_backend.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/syslog_backend.o" "libs/log/src/syslog_backend.cpp"
                 from ./boost/asio/detail/atomic_count.hpp:25,
                 from ./boost/asio/detail/task_io_service.hpp:24,
                 from ./boost/asio/impl/io_service.hpp:71,
                 from ./boost/asio/io_service.hpp:767,
                 from libs/log/src/syslog_backend.cpp:32:
In file included from ./boost/asio/detail/impl/posix_tss_ptr.ipp:24:0,
                 from ./boost/asio/detail/posix_tss_ptr.hpp:76,
                 from ./boost/asio/detail/tss_ptr.hpp:27,
                 from ./boost/asio/detail/call_stack.hpp:20,
                 from ./boost/asio/impl/handler_alloc_hook.ipp:19,
                 from ./boost/asio/handler_alloc_hook.hpp:80,
                 from ./boost/asio/detail/handler_alloc_helpers.hpp:21,
                 from ./boost/asio/detail/bind_handler.hpp:19,
                 from ./boost/asio/detail/wrapped_handler.hpp:18,
                 from ./boost/asio/io_service.hpp:24,
./boost/asio/error.hpp: At global scope:
./boost/asio/error.hpp:258:45: warning: 'boost::asio::error::system_category' defined but not used [-Wunused-variable]
 static const boost::system::error_category& system_category
./boost/asio/error.hpp:260:45: warning: 'boost::asio::error::netdb_category' defined but not used [-Wunused-variable]
 static const boost::system::error_category& netdb_category
./boost/asio/error.hpp:262:45: warning: 'boost::asio::error::addrinfo_category' defined but not used [-Wunused-variable]
 static const boost::system::error_category& addrinfo_category
./boost/asio/error.hpp:264:45: warning: 'boost::asio::error::misc_category' defined but not used [-Wunused-variable]
 static const boost::system::error_category& misc_category
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_specific.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_specific.o" "libs/log/src/thread_specific.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/once_block.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/once_block.o" "libs/log/src/once_block.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timestamp.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timestamp.o" "libs/log/src/timestamp.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/threadsafe_queue.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/threadsafe_queue.o" "libs/log/src/threadsafe_queue.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/event.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/event.o" "libs/log/src/event.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/trivial.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/trivial.o" "libs/log/src/trivial.cpp"
In file included from ./boost/smart_ptr/detail/atomic_count.hpp:80:0,
                 from ./boost/log/attributes/attribute_set.hpp:25,
                 from ./boost/log/sources/basic_logger.hpp:34,
                 from ./boost/log/sources/severity_logger.hpp:23,
                 from ./boost/log/trivial.hpp:22,
                 from libs/log/src/trivial.cpp:22:
./boost/smart_ptr/detail/atomic_count_sync.hpp: In member function 'long int boost::detail::atomic_count::operator++()':
./boost/smart_ptr/detail/atomic_count_sync.hpp:49:5: warning: no return statement in function returning non-void [-Wreturn-type]
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_file_backend.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_file_backend.o" "libs/log/src/text_file_backend.cpp"
                 from ./boost/log/sinks/text_file_backend.hpp:40,
                 from libs/log/src/text_file_backend.cpp:55:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/spirit_encoding.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/spirit_encoding.o" "libs/log/src/spirit_encoding.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/format_parser.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/format_parser.o" "libs/log/src/format_parser.cpp"
                 from libs/log/src/format_parser.cpp:26:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/date_time_format_parser.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/date_time_format_parser.o" "libs/log/src/date_time_format_parser.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/unhandled_exception_count.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/unhandled_exception_count.o" "libs/log/src/unhandled_exception_count.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/dump.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/dump.o" "libs/log/src/dump.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/parser_utils.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_DYN_LINK=1 -DBOOST_LOG_SETUP_BUILDING_THE_LIB=1 -DBOOST_LOG_SETUP_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/parser_utils.o" "libs/log/src/parser_utils.cpp"
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/init_from_stream.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_DYN_LINK=1 -DBOOST_LOG_SETUP_BUILDING_THE_LIB=1 -DBOOST_LOG_SETUP_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/init_from_stream.o" "libs/log/src/init_from_stream.cpp"
                 from ./boost/smart_ptr/intrusive_ref_counter.hpp:19,
                 from ./boost/log/attributes/attribute.hpp:21,
                 from ./boost/log/utility/setup/from_settings.hpp:24,
                 from libs/log/src/init_from_stream.cpp:19:
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope_format_parser.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_BUILDING_THE_LIB=1 -DBOOST_LOG_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope_format_parser.o" "libs/log/src/named_scope_format_parser.cpp"
                 from libs/log/src/named_scope_format_parser.cpp:27:
boost-1.60.0-r0 do_compile: gcc.link.dll /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/libboost_log.so.1.60.0
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"    -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/libboost_log.so.1.60.0" -Wl,-h -Wl,libboost_log.so.1.60.0 -shared -Wl,--start-group "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_name.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_set.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/attribute_value_set.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/code_conversion.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/core.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/record_ostream.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/severity_level.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/global_logger_storage.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_name.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/process_id.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_id.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timer.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/exceptions.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_attribute_names.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/default_sink.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_ostream_backend.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_file_backend.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/text_multifile_backend.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/syslog_backend.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/thread_specific.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/once_block.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/timestamp.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/threadsafe_queue.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/event.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/trivial.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/spirit_encoding.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/format_parser.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/date_time_format_parser.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/named_scope_format_parser.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/unhandled_exception_count.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/dump.o" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/atomic/build/aca09349fdb84d131321425f6c3a38ed/libboost_atomic.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/chrono/build/aca09349fdb84d131321425f6c3a38ed/libboost_chrono.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/date_time/build/aca09349fdb84d131321425f6c3a38ed/libboost_date_time.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/filesystem/build/aca09349fdb84d131321425f6c3a38ed/libboost_filesystem.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/regex/build/aca09349fdb84d131321425f6c3a38ed/libboost_regex.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/thread/build/aca09349fdb84d131321425f6c3a38ed/libboost_thread.so.1.60.0" "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/system/build/aca09349fdb84d131321425f6c3a38ed/libboost_system.so.1.60.0"  -Wl,-Bstatic  -Wl,-Bdynamic -lrt -lrt -Wl,--end-group -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -pthread
boost-1.60.0-r0 do_compile: common.copy stage/lib/libboost_log.so.1.60.0
    cp "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/libboost_log.so.1.60.0"  "stage/lib/libboost_log.so.1.60.0"
boost-1.60.0-r0 do_compile: ln-UNIX stage/lib/libboost_log.so
    ln -f -s 'libboost_log.so.1.60.0' 'stage/lib/libboost_log.so'
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/settings_parser.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_DYN_LINK=1 -DBOOST_LOG_SETUP_BUILDING_THE_LIB=1 -DBOOST_LOG_SETUP_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/settings_parser.o" "libs/log/src/settings_parser.cpp"
virtual memory exhausted: Cannot allocate memory
boost-1.60.0-r0 do_compile: gcc.compile.c++ /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/init_from_settings.o
    "arm-poky-linux-gnueabi-g++" "-march=armv7-a" "-mfpu=neon" "-mfloat-abi=hard" "-mcpu=cortex-a9" "-Wl,-O1" "-Wl,--hash-style=gnu" "-Wl,--as-needed" "--sysroot=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd"  -ftemplate-depth-128  -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0=/usr/src/debug/boost/1.60.0-r0 -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/x/imx6/fsl-release-bsp/build-x11/tmp/sysroots/imx6qsabresd=  -fvisibility-inlines-hidden -O3 -finline-functions -Wno-inline -Wall -pthread -fPIC -fno-strict-aliasing -ftemplate-depth-1024 -fvisibility=hidden -DBOOST_ALL_NO_LIB=1 -DBOOST_ATOMIC_DYN_LINK=1 -DBOOST_CHRONO_DYN_LINK=1 -DBOOST_DATE_TIME_DYN_LINK=1 -DBOOST_FILESYSTEM_DYN_LINK=1 -DBOOST_LOG_DYN_LINK=1 -DBOOST_LOG_SETUP_BUILDING_THE_LIB=1 -DBOOST_LOG_SETUP_DLL -DBOOST_LOG_USE_NATIVE_SYSLOG -DBOOST_LOG_WITHOUT_EVENT_LOG -DBOOST_SPIRIT_USE_PHOENIX_V3=1 -DBOOST_SYSTEM_DYN_LINK=1 -DBOOST_SYSTEM_NO_DEPRECATED -DBOOST_THREAD_BUILD_DLL=1 -DBOOST_THREAD_DONT_USE_CHRONO=1 -DBOOST_THREAD_POSIX -DBOOST_THREAD_USE_DLL=1 -DDATE_TIME_INLINE -DNDEBUG -D_GNU_SOURCE=1 -D_XOPEN_SOURCE=600  -I"." -c -o "/home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/boost_1_60_0/arm-poky-linux-gnueabi/boost/bin.v2/libs/log/build/8208f58b5e252bb068de8fecdebc659d/init_from_settings.o" "libs/log/src/init_from_settings.cpp"
                 from ./boost/log/attributes/attribute_value_set.hpp:26,
                 from ./boost/log/core/record.hpp:21,
                 from ./boost/log/core/core.hpp:23,
                 from ./boost/log/core.hpp:20,
                 from libs/log/src/init_from_settings.cpp:53:
In file included from ./boost/asio/ip/impl/address_v4.ipp:21:0,
                 from ./boost/asio/ip/address_v4.hpp:240,
                 from ./boost/asio/ip/address.hpp:21,
                 from libs/log/src/init_from_settings.cpp:65:
boost-1.60.0-r0 do_compile: ...failed updating 1 target...
boost-1.60.0-r0 do_compile: + bb_exit_handler
+ ret=1
+ echo WARNING: exit code 1 from a shell command.
ERROR: boost-1.60.0-r0 do_compile: Function failed: do_compile (log file is located at /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/temp/log.do_compile.8886)
ERROR: Logfile of failure stored in: /home/x/imx6/fsl-release-bsp/build-x11/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/boost/1.60.0-r0/temp/log.do_compile.8886
Log data follows:
virtual memory exhausted: Cannot allocate memory??
$ cat /proc/meminfo
MemTotal:        2048316 kB
MemFree:         1750688 kB
MemAvailable:    1727876 kB
Buffers:           12244 kB
Cached:            79816 kB
SwapCached:            0 kB
Active:           148992 kB
Inactive:          63444 kB
Active(anon):     125908 kB
Inactive(anon):     8900 kB
Active(file):      23084 kB
Inactive(file):    54544 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:        120588 kB
Mapped:            34264 kB
Shmem:             14220 kB
Slab:              43928 kB
SReclaimable:      27468 kB
SUnreclaim:        16460 kB
KernelStack:        3440 kB
PageTables:        14784 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     1024156 kB
Committed_AS:     977416 kB
VmallocTotal:   34359738367 kB
VmallocUsed:           0 kB
VmallocChunk:          0 kB
HardwareCorrupted:     0 kB
AnonHugePages:     34816 kB
CmaTotal:              0 kB
CmaFree:               0 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
DirectMap4k:       73664 kB
DirectMap2M:     2023424 kB
Labels (2)
liguoqing
The cause of the problem is unclear, probably due to too small virtual machine memory (2GB) or to the virtual machine itself.
Replaced 4GB of memory and non-virtual machine way, the problem is not again.
