When using VxWorks 7.0 for dual-screen GPU rendering on the i.MX6Q platform, extremely rare Data Abort exceptions occur, typically related to memory inconsistency, resource contention, or timing vulnerabilities in the Vivante GPU driver in multi-display controller (IPU) environments. The following are common causes and troubleshooting directions for this type of problem:
Memory Inconsistency and Cache Coherency This is the most common cause of Data Aborts in real-time operating systems such as VxWorks:
GPU and CPU cache misalignment: The i.MX6Q's GPU is not within the ARM's Snoop Control Unit. If the application layer updates the video memory data but does not manually execute cacheFlush(), or if the CPU immediately accesses the region after the GPU finishes drawing and does not execute cacheInvalidate(), it may result in illegal address offsets or data corruption, triggering an abort
