We're usb printer "GPrinter" on imx6 device. It's OK now for first plugin.
But if we plug out the plugin the device again, it will throw "Device or resource busy" when access the device.
Any suggestion about this problem? Thank you!
Software version:
android 4.04
linux 3.0.35
Test steps:
1. Configure and build linux usb printer as a module.
After building, we can get the module files
kernel_imx/drivers/usb/class/usblp.ko
2. Insert the module on imx6
insmod usblp.ko
3. Plugin the USB printer.
After plugin the printer, we found the driver was successfully install, and then we create the device file manually
busybox mknod /dev/printer c 180 0
4. Output text to printer, It's OK!
echo "text" > /dev/printer
5. Plug out the usb printer, and plug in again.
After that we found the USB device was successfully enumerated.
But if we try to output text to the printer device
It gives error "Device or resource busy".
BTW, we tested the printer on both PC linux and AllWinner android,
and found no problem after plug out and plug in the device.
