Anybody has tried to switch kernel tick from gpt to epit? It looks like that kernel only has
CONFIG_MXC_USE_EPIT supported for mx35
Jim
Hi Jim
there is epit driver in linux sources epit.c
http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/mach-imx/epit.c?id=rel_imx...
and description in sect.3.3 Timer attached Linux Manual
igor: Thank you very much for the info! I will give it a try.
