Hello everyone,
We want to support UHS-I mode on our board for our sd-card (sd3 port of imx). Hardware wise, we kind of copied the sabre sd automative schematics,but we didn't wired the sd3 RST signal to a power regulator to switch off and on the sd-card power (that is, the power of the sd-card is always switched on).
In the imx6qdl-sabreauto.dtsi, at the usdhc3 declaration there is a paragraph stating that power off is needed for SD3.0 card re-enumeration in UHS mode.
Hence, my question is, is it absolutely mandatory to have a vmmc-regulator with power off / on declared on SD3_RST pin declared to support UHS mode at run time ? (not at boot).
Thank you guys,
ps : I'm using a 3.10.17 freescale linux kernel.
Phil
Solved! Go to Solution.
Hi Phil
according to sd specs seems this is needed:
https://www.sdcard.org/downloads/pls/pdf/part1_410.pdf
p.150 sect.6.4.1.5 Power Down and Power Cycle
If the host needs to change the operating voltage, a power cycle is required.
Hi Phil
Thanks Igor, looking at the document you linked it seems power cycle is required as you said. We will modify the hardware to support that.
Phil
