imx6 run weston with --backend=drm-backend.so failed
7,558件の閲覧回数
wongj
i ported weston on imx6 , and if running weston with --backend=fbdev-backend.so ,it was ok.
but if running weston with --backend=drm-backend.so ,it was failed, with info no drm device found.
how could i solve this problems
2 返答(返信)
6,938件の閲覧回数
art
There seems to be no drm-backend.so backend support on i.MX6. Please follow the Section 5.2 of the attached document for the details on how to operate Wayland/Weston on the i.MX6 series processors.
6,938件の閲覧回数
wongj
Thank you for your help, and i have solved this problem with weston version 1.9
