I would like to connect 2 screens (using android OS) that will act like one big screen (same as Linux xrandr) can that be achieved ?
Android to this date does not have the capability to do "extended display", it can only clone it to an external display.
I would recommend that you check an API available since Android 4.2, it is called "Presentation" and it allows you to "extend" the display to do particular activities, though it does not work as you would like it to work.
Sergio
