imx6 base board, udoo quad and running android 4.3 on it.
1,263 次查看
dorel
Hello guys, i have imx6 base board, udoo quad and running android 4.3 on it.
I want to use an egalax usb touchscreen driver on it but i can't make it working.
I try it to compile the kernel and check the usb egalax driver.
I try it to add file :
  • /system/usr/idc/Vendor_XXXX_Product_XXXX_Version_XXXX.idc
  • /system/usr/idc/Vendor_XXXX_Product_XXXX.idc
  • /system/usr/idc/DEVICE_NAME.idc
I also follw it a tutorial from provider , and i patch it same file and compile kernel, but nothing sims to be working.
Do you guys know some ways to fix this problem?
Thank you.
Sorry for my English.
标签 (2)
914 次查看
haoranwang
     For change the defconfig you cannot cp .config arch/arm/configs***.
     Please follow those steps:
     1. $cd kernel_imx
     2. $make imx6_udoo_android_defconfig
   3. make menuconfig  and change the configs
     4. save config to .config and exit the menuconfig
     5.  $make savedefconfig
     6. $cp defconfig  arch/arm/configs/imx6_udoo_android_defconfig
     7.  $cd .. && mm bootimage
     Then flash your new generated boot.img to board and try again.
BRs,
Haoran
4 回复数
914 次查看
haoranwang
Hi @dorel
     I think the kernel is not ready for your touchscreen.
     Did your patch will generate new Kconfig in kernel?
     If so you should enable the config in arch/arm/configs/imx6_android_defconfig .
     Because the config changed in the "make menuconfig" will be replace by the arch/arm/configs/imx6_android_defconfig.
     BTW: we are not gays :smileyhappy:
BRs,
Haoran
914 次查看
dorel
Hi , sorry for ''gays'' :smileyhappy: i edit the post.
It's ready. It's working and i think you right.
I followed another guide for activate sata and the difference between udoo forum guide and ather guide is this:
cp .config arch/arm/configs/imx6_udoo_android_defconfig - (this was not mentioned in udoo forum guide)
It is correct? it is what you say?
Thank you.
915 次查看
haoranwang
     1. $cd kernel_imx
BRs,
Haoran
914 次查看
dorel
Thank you .
