Hi Arnaud,
It seems that most of the Android implementations include a screen, as it is required for “Device Compatibility”, as indicated on Android developer’s webpage:
http://developer.android.com/guide/practices/compatibility.html#Screens
If you really don’t need the screen and you only need the Android API, maybe you should check the ADB support in order to verify that you will be able to use it for your end application purposes.
Hope this will be useful for you.
Best regards!
/Carlos
