hi all
recently, I imported a mipi camera to IMX6 AI board , refered to ov5640_mipi.c
now , when i clicked the cam apk , IMX6 can receive the mipi data , but the picture is not correct when preview .
who can help me !
thanks a lot !
attached is the picture when preview .
Hi Xiaoxiong
you should modify mipi sources for your sensor, as it was performed at link below
Re: i.MX6 OV5647 Bayer sensor driver (ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0)
chip
chipexpert . Thanks for your help. My question had been resolved.
I had modify only 2 things . One is the IPU Channel : using IPU1 CSI0 in IMX6Q . The other is that modify the previewsize setting in ioctl_enum_framesizes before preview.
The picture is error , because of the pixel size in kernel is not match the HAL setting .
