imx5x vpu encode yuv to h264
JayZhang
Hi all,
When I used the mxc_vpu_test to encode the yuv to h264 from camera, I found the encoded file had some problem, which I played the h264 file, it run a little fast.
Firstly, I guess it is the problem of fps, but I changed the fps to 15(default is 30), the encoded video is also 30 fps, anyone can help me ?
Original Attachment has been moved to: f15.264.zip
Tags (5)
LeonardoSandova
Specialist I
can you post the cmd line you used to do the encoding? can you try the same using GStreamer? For this, take a look at this document
karina_valencia
NXP Apps Support
NXP Apps Support
no update from customer
