hi,
I was tested usb device in mx53 board and not working device mode.
My Menuconfig settings are here below.
First one i was set for following menuconfig settings:
"CONFIG_MXC_OTG, CONFIG_USB_OTG\n
"CONFIG_USB_EHCI_ARC_OTG\n"
"OTG device config\n"
"CONFIG_USB_GADGET\n"
I got in serial port/console message while i was insert and remove in USB device cable(J3).
usb wakeup is here
otg host ID wakeup
hub 1-0:1.0: activate --> -22
usb wakeup is here
otg host ID wakeup
also usb driver not installed in this settings
second one i was set USB device mode settings and udb driver not installed .
in device mode was not working and if any settings are missing compare to above device mode configuration please tell me the correct procedure to enable imx53qsb device mode .
Did you insert any of the gadget drivers. Like "modprobe g_file_storage file=....."?
hi Vladan,
no .. necessary for need to insert this one ah=?.
Sorry, didn't understand the comment. If you haven't used g_file_storage before there's some info here:
thanks ,i will check this document..
