Good Day,
I have purchased a iMx53 QSB which works with no issue initially. I then changed the default user name and password (lucid) to another custom one.
However, on re-booting, it shows only a black screen.
After much checking and only when I telnet to the hardware from another PC do I realise that the start-up code has stopped and prompted one to input the user name and password. It does not boot into the Linux window and prompt one to input the user name and password in the window mode.
At this point of time, I have forgotten the changed user name and password.
Is there any means to reset the username and password to the default lucid?
Or any other means to bypass this?
For your valuable advice
