when i insert USB with wifi dongle i see imx28 is getting shut down
following are the log
Following is the log
[ 102.640000] mxs-battery mxs-battery.0: vdd5v droop interrupt occurred
[ 102.640000].Done, shutting down
[ 102.640000] Successfully sent signal
[ 102.640000] mxs-battery mxs-battery.0: new 5v disconnection detected
[ 102.660000] ehci_fsl_bus_resume, Host 1
