I found that the SGTL5000 is having only 45mW max in output in headphone output. But i want to connect the loud speaker to SGTL5000. I tried connecting speaker into headphone output and it's not giving very good sound. From the SGTL5000 datasheet understand that lineout is for connecting speaker. how to route the audio to linueout instead of headphone output. Do you have anyother IC recommend to give more watts of audio output.
Thanks & Regards,
RAM
